Interesting
Ebay chip. (not a question thread)
Got mine too!
So I have had a few hurdles to jump today. I decided to go ahead and install the 19lb injectors first. Before you give me crap, remember this is about the horsepower gain from the CHIP only, so it makes sense to have the injectors installed for the baseline. Plus I didn't want to be taking up precious dyno time installing them.
Got the injectors in, I was a little concerned when I found that 2 came out missing their caps. After some careful consideration and inspection of the injectors themselves we came to the conclusion that they had been missing for a while. Nevertheless, we ran one of those bolt grabbers down into the intake to check for any loose items, everything checked out. After installing the new injectors we disconnected the coil pack for a couple turn overs to check for noise, all seemed well so I started it up.
I recommend 19lb injectors to anyone without a tune even. Idles smoother, and just plain runs better.
Then came the chip install (don't worry, we are working on getting dyno time, at which point the chip will be swapped back out for before and after runs) I removed the ECM to find a 153 in there.
That's OK, I informed my business partner that his Vert' that is just sitting will be a donor car for now. Swapped his 173 ECM into mine, and did a test start. Ran great. Then I installed the chip, filled her up with some 93 octane and went for a drive.
Honestly, I can't feel any difference other than a smoooooooth power band and the 7k rev limiter will be nice for auto-X.
lucky for us, the butt dyno won't be the only test to see for sure. We are hoping to get the car on the dyno this week or early next. Stay tuned for real numbers!No E30 ClubOriginally posted by MrBurgundyAnyways, mustangs are gay and mini vans are faster than your car, you just have to deal with that.Comment
On another note, today was busy! Got a Cobalt SS/TC tune in, and C/F wrapped the roof of an STI. Business is boomin!No E30 ClubOriginally posted by MrBurgundyAnyways, mustangs are gay and mini vans are faster than your car, you just have to deal with that.Comment
19pound mustang injectors without chip did increase mpg a little, noisy injectors and power remain the same.
with ebay chip you recommended dramatically increase my mpg, rpm rev faster specially after 3k,can easily hit 100mph,injectors became quiet, you can hear air passes through muffler faster and I pass my inspection yesterday without a problem.
^m42 using 93 octane.
problem
waited 3 weeks for ebay chip.
What on god's green earth are you talking about?
If only I had the money to spare for the dyno time, I have in my possession:
A stock 173
A 173 with the Ebay chip
AND a 173 with a war chip, which could be tested normally (On their tune for the AFM), and with the MAF conversion (Again, their tune).
I could do 4 different setups on the dyno... Test them all on STOCK injectors. back to back...
Sigh... Maybe I should find out how much it would cost. I's curious.Comment
Sorry for the delay guys.
The shop we take our cars to for the dyno has had theirs tied up. The owner just finished his 6.2 ls swap into a Foxbody. It may take longer than expected.No E30 ClubOriginally posted by MrBurgundyAnyways, mustangs are gay and mini vans are faster than your car, you just have to deal with that.Comment
Butt dyno results? (assuming they're fairly similarly modded otherwise)If only I had the money to spare for the dyno time, I have in my possession:
A stock 173
Sigh... Maybe I should find out how much it would cost. I's curious.The first car I ever rode in was an e30
1992 Mauritiusblau Vert
2011 Alpinweiss 335is coupe
2002 540i/6 Black/Black
2003 GSX-R 750 (RIP)Comment
But see, even a stack of completely stock 173 ECUs can give you different HP levels. That's a little cheater technique you get from racing in a spec series. So it would technically have to be the same ECU with the only thing changing would be the chip.If only I had the money to spare for the dyno time, I have in my possession:
A stock 173
DComment
Here are my results, using a Mark D'Sylva chip in an '027' ECU and dyno test results at York Auto. With the addition of a 3.46 LSD Diff, my '83 528e has gained a major performance improvement. I also comment on my experience with Dinan and Conforti chip tests in the same car. I have a Metric Mechanic HiFlo ST Cylinder Head, but have not yet installed it, due to other priorities which keep stealing my time. You know it how goes.
FWIW
-RodRod's 528e support web site
A car can be restored many times. It is original only once.Comment
Looks like some of these newer chips, that are affordable to the average e30 owner, will bring in even more HP/dollar. That's good to know that progress is being made.summer of 2006 - For those of you who look at the total cost of any modification you make to an engine, in terms of cost per RWHP gained,...resulted in a cost of $12.66 per HP ($200/15.8 RWHP=$12.66) gained!Last edited by george graves; 03-19-2012, 04:19 AM.Originally posted by Matt-Bhey does anyone know anyone who gets upset and makes electronics?Comment
I believe these chips will be complimented with the installation of 17.5 or 19 lb injectors. I just did a 17.5 injector swap this weekend and the car feels smoother. And I have been running an eBay chip on stock injectors before the swap. Also did a valve adjustment, so that may have helped a bit.1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
2012 Passat TDI - DD Duty
2008 GMC Yukon XL Denali - Kiddie hauler/grocery getterComment
