Ebay chip. (not a question thread)
  • 5Toes
    • 9836
    #61
    Any updates?
    • Exodus_2pt0
      • 5943
      #62
      Not yet :(
      No E30 Club
      • bowtie2bimmer
        • 830
        #63
        Are you driving your car around in the mean time? Your ecu will adapt to the new injectors so that would be key to have a proper "baseline" pull
        1987 BMW 325ic - Emma
        • Exodus_2pt0
          • 5943
          #64
          Yea I've put a few hundred miles on it. With the shop just starting out we don't have a ton of extra cash. Should be able to have something at the end of the month after the bills are paid.
          Stay tuned, I apologize for the delay.
          No E30 Club
          • Northern
            I like cupcakes & sh!tboxes
            • 5276
            #65
            So with a chip, you can still run the 17 or 19 4-pintle e36 injectors? That's something I was unsure of before.
            Originally posted by priapism
            Originally posted by shameson
            • bowtie2bimmer
              • 830
              #66
              you can run 17/19 with any chip or stock as the ecu is adaptable.
              However certain legit chip manufacturers actually make a specific tune for the larger injectors (i.e. MarkD)
              • Vivek
                attention whore/retard/bitch
                • 6167
                #67
                Butt dyne maybe..?
                1992 Mauritiusblau Vert
                2011 Alpinweiss 335is coupe
                2002 540i/6 Black/Black
                2003 GSX-R 750 (RIP)
                • custom e30
                  • Nov 2009
                  • 347
                  #68
                  dude, with out doing the injectors and dyno, i put a chip in my ar and wow, i seen a good difference...u will be happy no matter what
                  • bowtie2bimmer
                    • 830
                    #69
                    But do you have the numbers to back it up
                    • Exodus_2pt0
                      • 5943
                      #70
                      Soon, we either will, or won't. Dyno has been put on the back burner but I will post up as soon as it happens. I haven't forgotten!
                      No E30 Club
                      • 5Toes
                        • 9836
                        #71
                        bump
                        • Vivek
                          • 6167
                          #72
                          Been a bit over a month...still nothing man?
                          • AlpineM325
                            • Aug 2007
                            • 373
                            #73
                            I purchases the same ebay chip as the op, but im having problems with it. My idle bounces With the chip installed. Bounces worse in closed loop but still bounces in open look. Anyone else have this problem?
                            WTB
                            -convertible carpet, no rips, in socal.
                            -s52, s50, m52, m54
                            -harness, accessories, transmission
                            • jink0619
                              • 808
                              #74
                              ^ yes I have the same problem, it also dies at idle sometimes :(
                              E30love
                              • MaksV
                                • 1042
                                #75
                                That means you are not reading anything of the o2 sensor, and the tune is designed to compensate off that map.
                                Also the e30/pre96 e34/6 dme's do not "adapt" there is no coding for looking at values and making adjustments from them. there is simply a series of maps with AFR ect, that it reads from based on the conditions.
                                CHEAP REBUILT INJECTORS
                                Need Quality Brakes? BimmerBrakes has it!
                                For anything Else go with BluntTech!
