Sandwich adapter vs. distribution block for m20
  • Jester10
    • Mar 2012
    • 2
    Hey guys,
    Just wondering what is preferred for installing oil temp / oil pressure gauges for the m20? It looks like the oil filter sandwich adapter and the small oil distribution blocks are the 2 most popular options. Anyone know the pros and cons of each setup?
    Thanks in advance.
  • 603Racing
    • Dec 2010
    • 612
    I have read on here that the blocks can leak, but I know a couple people that have them installed and have no issues with them. I'm not very familiar with sandwiches.
    I just ordered my block and pressure gauge earlier this week.
    90 325i DD/Track
    03 Durango 5.9
    Originally posted by e30mpg
    It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
    • Jester10
      • Mar 2012
      • 2
      Yeah, it seems like some people have been using Teflon tape before inserting the senders to cut down on leaks. Which block did you get if you don't mind me asking?
        The best place for the oil temperature sensor is a place where oil will flow by the sensor. Welding a bug into the pan is one good solution. If the oil cooler thermostat has been modified for continuous flow placing the sensor in the return line to the block is the best place. A reasonable alternative to those is to drill and tap the oil filter adapter bolt.
        For pressure, an adapter that goes where the oil pressure switch mounts is good. If using an electrical oil pressure gauge mount it on the engine or better yet the fender and run A/N SS hose from the adapter.
        • 5Toes
          • 9836
          Goto a local hydraulic shop and have them fab up a custom adapter/line to your pressure sender
          Should be $35 ish, that is what I am doing. Only $5 more than buying an adapter, the SS line and A/N fittings/adapters
          Also, if your sender has a 7psi contact, you can splice that into the stock sender's harness..
          • TobyB
            • 5297
            The pan itself is thick enough in places to thread and tap...
            ...which will tell you oil temp in the pan.
            I whacked the stock sender and brazed on an AN-3 fitting for the pressure gauge.
            t
