So, about those Injectors...
  • Savagefurai
    • Apr 2011
    • 970
    What would prevent them from letting fuel through?
    They are rebuilt injectors
    Fuel pressure is good @ the rail
    Cps is new
    Relays are good
    No vacuum leaks
    Fires up with starter fluid
    Tested damn near everything i can think of.
    DME
    AFM
    TPS
    ICV
    FPR
    etc
    etc
    etc
    WTF is preventing my car from starting?
    BTW, its an 88 Seta. M20B27
    Please help, I've checked and rechecked these forums and the usual suspects for a no start. Im at a dead end. :(
    Thanks.
    Currently without an e30. Will probably die soon.
  • paperplane94
    • Jul 2011
    • 420
    Add wiring, improperly rebuilt injector(s). How did you test the DME, because that is the last possible possibility :)
      What is the rail fuel pressure when cranking?
      Are the injectors firing (use a noid light)?
      • e30Rooster
        • Jan 2010
        • 958
        IIRC the eta has two crank sensors did you check both?
        • Savagefurai
          • Apr 2011
          • 970
          uh, not the super eta. It has the one like a late model on the front of the motor.
          None @ the bell housing. If thats what you're talking about.
          Still cant find the problem tho. Checked all the fuses and relays and now im on to the wiring harness itself. ugh...
          ... maybe i'll part it out.
          • Cabriolet
            • 9620
            did you swap the CPS and wire coming from the spark plugs? you know under the diagnostic port.
            Much wow
            I hate 4 doors
            • SmokeE30
              • 1730
              did u rebild the stock injectors or replace them with another set? the SETA cant use the regular eta's 19lb injectors for example and wouldn't fire them
              Shawn @ Bimmerbuddies
              Bimmerbuddies LLC
              717-388-1256
              2971a Roundtop Rd, Middletown PA 17057
              bimmerbuddiesllc@gmail.com
              • Savagefurai
                • Apr 2011
                • 970
                well, after rebuilding the original ones, i sourced a set of m50 17lb injectors and rebuilt those, To no avail.
                out of cuiosity tho, What would prevent the seta from firing the eta 19pounders?
                • Savagefurai
                  • Apr 2011
                  • 970
                  Im up for someone to come help troubleshoot with me cuz the car still is out of order. Ugh.
                  • blueapplesoda
                    • Dec 2005
                    • 1904
                    did you accidentally switch the fuel lines?
                    • Savagefurai
                      • Apr 2011
                      • 970
                      I don't think i did.
                      Or at least i hope not.
                      Everything looks like its connected right...
                      • 603Racing
                        • Dec 2010
                        • 612
                        +1 to jlevie's comment.
                        Noid light to test injector pulse.
                        If it's all the injectors are not working, then there's only a few things that can cause it. You've listed that you checked most of them. I'd do a noid light test, very easy.
                        90 325i DD/Track
                        03 Durango 5.9
                        Originally posted by e30mpg
                        It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
                          • 34844
                          they are low impedance. you'll fry the ECU.
                          • Savagefurai
                            • Apr 2011
                            • 970
                            Thats what i was thinking, but the 17lb ones should be okay tho cuz they should be high impedance right?
