how to rotate cam w head off
  • bastianshaw
    • Jan 2007
    • 2210
    I got a spare 885 i want to practice adjusing the valves, any ideas?
  • 0000000000
    • 473
    with the cam gear?
    • bastianshaw
      • Jan 2007
      • 2210
      Originally posted by 0000000000
      with the cam gear?
      what just grab it and turn? your a better man than me!
      • JTDay
        • Dec 2009
        • 521
        you see, there's a torx "bolt" that holds the cam gear on. You "turn" that "bolt" to make the cam turn over. Dont do it on a flat surface if you plan on using the head in the future as you risk damaging the valves.
        Past: 1987 325iS, Bilsteins - HR Sports
        Present: 1999 M3, Koni Yellows - HR Sports - GC Camber Plates - UUC Swaybars - UUC SSK - AFE Intake - Stromung Catback
        2009 Mazdaspeed3, Short Ram Intake - Turbo Inlet Pipe - 2nd cat Delete - Catback - Fuel Pump Internals - Cobb Accessport - Stratified E30 tune - 294/342 - SPC Camber Arms - CPE Rear Motor Mount
        • paperplane94
          • Jul 2011
          • 420
          ^turn it right.
          • Balleristic31
            • Aug 2009
            • 4198
            I used an impact gun on the torx tightening to quickly rotate the head assembly off the car.
            -NICK
            • TobyB
              • 5297
              well, that probably won't do the cam bearings any favors without oil... nor the cam or rockers... jus' sayin'.
              t
              • Cabriolet
                • 9620
                never put a head back together without assembly lube or at least oil. i've been able to turn all my 885/AMC heads by hand and cam gear and im no big guy.
                Much wow
                I hate 4 doors
                  Use a strap wrench on the cam sprocket.
                  • vert_this
                    • Feb 2012
                    • 395
                    or an old timing belt and a pair of vise grips
