my e30 wont go higher than 2000rpm help
  • lbc318is
    • May 2011
    • 182
    i have a 1991 bmw 325i 4 door
    problem
    thing done to it
    tps sensor
    maf sensor
    idle control valve
    o2 sensor
    spark plugs
    wires
    cap n rotor
    timing
    fuel pump
    can some one plz help me out i dont know wat to do
  • paperplane94
    • Jul 2011
    • 420
    How is the trans?
    IT sounds like some kind of limp home mode.
    • alfie
      • Aug 2011
      • 36
      same here but the only thing i havent done is adjust the tps sensor i hope someone can help us both..
      • LJ851
        • 7918
        A bad crank position sensor can cause the symptom you have.
        Lorin
        The M30 is God's engine.
          A bad CPS or a fuel delivery problem would be my first suspicions.
          • Gregs///M
            • Mar 2012
            • 2459
            You "did" the maf sensor? Not sure what that means but I've seen problems like this with the AFM, which is what your car has, not the MAF. Double check the output and inputs to the AFM.
            Owner - Bavarian Restoration
            BMW and European Electronics Repair and Restoration
            www.BavRest.com
            My Feedback Thread
            Our Facebook!
            Follow our Instagram!
            • DTMbimmer07
              • 1485
              did you ever find the answer to your problem? my car is doing the same thing after i just swapped in my new built motor and its driving me insane
              • dnguyen1963
                • Nov 2011
                • 2648
                Which E30 model year uses AFM or MAF?
                • slammin.e28
                  שמע ישראל
                  • 12054
                  All of them are AFM stock.
                  • dnguyen1963
                    • Nov 2011
                    • 2648
                    So..MAF is used in post E30 models?
                    • slammin.e28
                      שמע ישראל
                      • 12054
                      Basically it follows the engine. AFM is M20, M30, M42, M10.
                      MAF is M50 and up. Basically all 24v+ engines are MAF, with the exception of "S" engines in M cars (M5, M6).
                      • dnguyen1963
                        • Nov 2011
                        • 2648
                        Thanks!
