Working on refining my 2.8 and next on the list was a smoke test to check for vacuum leaks. The car may never idle smoothly (298* cam) but I know it could be better, plus the car occasionally throws the code for an incorrect air/fuel ratio at idle.
So the smoke test revealed two leaks:
1) Throttle shaft in the TB. This was a pretty bad leak too.
2) Valve cover gasket. Leaking really badly, but shouldn't be a tough fix with a new gasket. I guess they're pretty much one time use; I've had this gasket on and off twice.
Now for my main question: What to do about the TB?
Can they be rebuilt? I haven't seen any kits or anything. I haven't priced out a new one either, but I'm sure it's frightening.
I ran across these: http://www.westcoastriots.com/htmlfiles/Products.html Not sure what the stock plate diameter is, but might this be the best option? The motor is outputting far more than stock, so a bigger TB might be worthwhile in its own right, plus it would solve the vac. leak.
Any thoughts?
Any thoughts?
