aftermarket gauge Q.
  • 89 e30
    • 249
    Probably gonna install some aftermarket gauges on my m20 (oil pressure and coolant temp).so my question is, could I just replace the stock oil pressure sender with a aftermarket one, same with the coolant or do i have to get an adapter
    BIMMER für IMMER
  • Gregs///M
    • Mar 2012
    • 2459
    Depends if you can find senders with metric fittings to match the OEM senders. Im sure they are out there. try egauges.com
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • 89 e30
      • 249
      I can't use the pressure sender that's in there now right?
      BIMMER für IMMER
      • reelizmpro
        • 9553
        You can if u use an adapter to tee it off. Or just get the right VDO sender with built in low warning switch.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • 89 e30
          • 249
          ^^ do you know where I can get one of those senders
          BIMMER für IMMER
