does any one have any experience them? im looking to get one but was hoping some one could tell me the pros and cons. thanks guys
272 cam
Tags: None
Why would you be looking to.get one when you have no idea what it even does? I swear I see more people every day that just start throwing parts at their car because they saw someone online has one.
2012 MCSCC/NSSCC CP class champ
HSAX InstructorComment
injectors and a chip will definitely liven things up but you shouldn't run a cam too hard without a proper tune to go with it.....tune is way better
a few of the big guys on r3v, some who do machine work and build their own heads swear by the 274 or bust on NA motors....anything more and its considered unnecessary in their own wordsComment
Unfortunately the 885 head doesn't flow nearly as well as a hotter cam would like it to, the gains will be minimal.
'89 Alpine S52 with goodiesComment
Akorcovelos cool story gtfo. Thanks everyone else. I already have an maf and chip upgrade bigger injectors and headers on my dd. If anyone knows Does it have a different feel when it idles compared to stock?Comment
Also dont forget. Something like a cam needs extensive supporting mods for the engine to run well. I got some 19# injectors ready to go for you!Comment
There are so many aspects that come into play when choosing a camshaft. You have to take into account the amount of lift, duration, overlap, ect. all to suit the your engine combination and application its gonna be used. I'm no expert nor are many of the members on this forum. Your gonna have to read more into camshafts to understand what these number mean. I've only read into it a little.
If it were my engine I'd get a Schrick 284/272 dual pattern camshaft instead. Poorer flowing heads need more valve lift to allow more room for the fuel and air to come through, only to a level where you heads stops flowing cfm at x amount of lift. This camshaft still isn't radical but nice for a street car and it will go good with all the supporting mods you have already done to your car. But it would be better if you had more compression. So don't expect some serious gains.Comment
