felpro gaskets
  • TS87325IS
    • Sep 2006
    • 821
    felpro gaskets
    Anyone use felpro gaskets yet? Are they any good?
    mods: just meat and potatoes under the hood and wheaties on fire out back ;)
  • FLG
    • Sep 2011
    • 3165
    Use felpro on my charger and have never had issues.
    What gaskets are you using? Head gasket or other items?
    Sent from my Galaxy Nexus using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • cabriodster87
      • Jan 2011
      • 1042
      I have used Felpro for years, great head gasket kits, IMO. Just buttoned up a 2000 4.3 V6 Vortech, had every thing to finish the job from Valve seals to RTV black.
      Reich und Roll!
      • TS87325IS
        • Sep 2006
        • 821
        I just rebuilt my m20 and was trying to decide which gasket sets to get. I might give them a try.
          • 37833
          I've never used them for BMW stuff but they do make quality gaskets.
          Grover Beach, California
          BimmerHeads.com
            • 34844
            I *believe* they're the same gaskets as Goetze (or at least they're owned by the same company). regardless, they're usually good stuff.
            • SpecM
              • Oct 2005
              • 4531
              I use them all the time on Americans cars, Hondas, Subarus, Nissan etc in my shop. They are good quality gaskets, and are far superior to the OE gaskets on GMs.
              I've never used them on a European car before. Your NAPA should have a Goetze kit locally available.
              Sent from my Vortex
              1989 cirrisblau-metallic 325i
              • amazo
                • Mar 2012
                • 27
                I work at napa but in Canada, I can't locate Goetze in the head gasket just in head bolts
                • cabriodster87
                  • Jan 2011
                  • 1042
                  Found this from Goetze:http://www.fme-cat.com/PartDetailWin...0M20&t=1011676 here is the rest:http://www.fme-cat.com/Application.a...M20&cat=Engine
                  Reich und Roll!
                  • TS87325IS
                    • Sep 2006
                    • 821
                    I got my bottom end set today and the crankshaft seals say elring on them...gaskets look good.
                    • cabriodster87
                      • Jan 2011
                      • 1042
                      weird instructions
                      TORQUE SPECIFICATIONS ARE SHOWN IN FOOT-POUNDS
                      2nd Step: wait 20 minutes
                      Reich und Roll!
                        What is weird about about those instructions? The head bolts for an M20 head are torque-to-yield types. Likewise for the rod bolts.
                        You only want the torx head bolts and they (and the rod bolts) are one time use. To reduce the chance of wasting a set of bolts, when you re-install the head only bring them to initial torque until all of the engine is back together and the timing belt is on. If for any reason you need to remove the head before angle torquing the bolts they and the gasket can be reused.
                        Oh yeah, make sure both of the locating dowels are in place before installing the head.
                        • cabriodster87
                          • Jan 2011
                          • 1042
                          ^^ fixed
                          Reich und Roll!
