temperature sensor adapter?
  • DirtE Thirty
    • Nov 2011
    • 11
    Does anyone know who may make an adapter for an aftemarket temperature sensor to screw in? We are in the process of building a chump car and have removed the dash and installed aftermarket gauges (autometer I think) and the sensor for the temp gauge does not fit the factory location on the engine. I see several companies like IE offer an adapter that splices into a coolant hose, but these seem like they would give a less than accurate reading.
    VDO does have a sensor with threads that will match those in the thermostat housing.
    • Gregs///M
      • Mar 2012
      • 2459
      egauges.com has the adapters to make that happen.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • TobyB
        • 5298
        I found that a 1/2" to 3/8" adaptor would put the Autometer sender in a perfect spot-
        all you have to do is drill and tap for 3/8" npt... and on the late engine, there's
        just enough room on top of the tstat housing.
        t
