I putting my 89I motor in from my wrecked 4dr into an 88 SETA and have a couple questions.
First some details:
-The motor was pulled from the 89 in running condition, it was driven into the garage and pulled. Nothing was disconnected from the motor but the starter, the harness was pulled with it. I put a new starter in it when the motor went in since it's a bastard to change anyway.
-The 88 SETA was purchased not running (ended up being a broken #1 rod). Not sure if the fuel pump worked, key definitely engaged the starter.
On to the questions...
The 89 harness should plug into the c101 at the 88 fuse box and nothing needs to be changed right?
The fuel pump isn't turning on with the key, and the starter is not engaging. BUT, when I turn the key all the way forward to start, the radio does not cut off and I have interior power. I am 90% sure it functioned correctly before I pulled the motor, so I am inclined to believe it may be something I crossed or didn't put back right. I am not sure if the fuel pump worked before I pulled the SETA motor...
Where should I start first? Is the fuel pump/starter a related issue or two separate issues?
Thanks
First some details:
Thanks
