S50 crank, m20 stroker questions
  • Dagamus(NM)
    • 620
    Originally posted by SkiFree
    I have them.
    Old thread bump, but might you happen to still have these? How about the bolt/washer thing?
    Gun control means using both hands
    Sex, Drugs, Rock 'n roll. Pick two.
    • SkiFree
      • Jun 2011
      • 2766
      I posted that when I was still at IE. IE will still have them.
      (you have to call, they just don't want to sell to someone who isn't comfortable using heat. The ring is heated pretty dang hot, and if someone isn't careful/experienced they can get it caught cock-eyed when sliding it on).
      As a second option, John at WOT-Tech may still have some of the batch he did.
      ADAMS Autosport
      • Dagamus(NM)
        • 620
        Thanks. I will contact John. I cannot support IE. Well, I cannot support Jeff. Fuck that turd.
        • ForcedFirebird
          • Feb 2007
          • 8300
          The ones I make only need ~250° to slide on. Toaster oven works great hehe.
          john@m20guru.com
          Links:
          • Dagamus(NM)
            • 620
            I just emailed you John. How long at 250?
            • ForcedFirebird
              • Feb 2007
              • 8300
              Until it's heated through. Doesn't hurt to go a little higher, it gives more time to slide it on. The crank cools it pretty quickly, so make sure you have it on straight.
              john@m20guru.com
              Links:
              • Dagamus(NM)
                • 620
                Cool. I will pass a torch over it if I get it crooked.
                Thank you both for helping. Glad to not have to support IE or get fleeced by MM.
                • SkiFree
                  • Jun 2011
                  • 2766
                  Haha, ok cool. Glad you got it worked out.
                  ADAMS Autosport
