'87 325e - 327i Dyno results
  • JA1991
    • 452
    Wow soo good, i can't wait to do a head swap.
    [/quote]
      • 34844
      nice! actually, that's one of the better HP/torque curves i've seen from a 2.7/head swap. perhaps the 323i head is a better match than the 885 to the flat-topped pistons - those always end up being a bit down on power compared to a stock M20B25, just more torque. yours is about dead even on power and definitely more torque.
      Originally posted by durtyE30
      ~178HP @ Crank
      Very respectable.
      I'm donig an 885 head onto an 86 325e bottom end. Thinking of building the head up some, to get ~ 200HP @ crank ideally.
      what the hell sort of drivetrain loss are you using? there's no way it's 178bhp.
        • 34844
        Originally posted by Gary Horneck
        After planning this conversion for a year, I just had to see what the final results were. Wish a baseline 325e pull had happened, but from what I can find, looks like about 75-80 rwp? Is there a common formula for our cars to roughly determine crank output from rwp? I guessed seat of pants, a 60hp increase over the eta.
        stock eta should be more like 105-110bhp, not 80..
        here's one that put down 112whp at 3900rpm:
        it's definitely a big improvement over a stock eta, but it's certainly not a 60hp increase.
        • Gary Horneck
          • May 2011
          • 435
          Just going by the few assorted youtube videos showing a 325e on a dyno. Still think it was worth the conversion. Amazing that a 121hp engine only lost 9hp in frictional losses though.
          2011 335i/1995 Mercedes C220 (rallyx)
            • 34844
            it was probably underrated like many BMW engines
            anyway, even if you use a pretty standard HP loss (~15%) it still ends up at ~105whp.
            • rodpaine
              • 33
              Yup, my stock 1983 528e freshly tuned produced the following on the York Automotive dyno in Mt. Airy, MD:
              - 106.5 RWHP with stock ECU
              - 122.3 RWHP with E.A.T chip
              I talk about involving various ECU chips here and my experience with chips on other M20 engines in poor states of tune.
              -Rod
              Rod's 528e support web site
              A car can be restored many times. It is original only once.
              • e30trooper
                • 11576
                LOL that was my old eta
                Had 88 rwhp @ 4950 rpms , no chip just cone filter and cheap axle back muffler. Had tons a intake leaks. This was 3rd gear pulls
                This dyno read low #s so maybe on others might be around 95ish whp
                • iXe<30
                  • 143
                  ok ill be that guy.... how does this effect the awesome efficiency of the eta.... you guys probaby are having to much fun to care but im interested in a stroker for my ix esp if i can get better mpg and keep similar power/more torque.
                  • e30trooper
                    • 11576
                    With the 2.93 i still get great MPG. Even with the 2.93 the car still flys, however there's plenty of room for improvement
                    1st and 2nd gear pull , eta block with refreshed/decked 885 head full 1.3 swap , ebay b3 chip copy. open 2.93 diff
                    • iXe<30
                      • 143
                      [quote=e30trooper;3232318]With the 2.93 i still get great MPG. Even with the 2.93 the car still flys, however there's plenty of room for improvement
                      cool thanks man. any approx numbers for gas mileage?
                      • e30trooper
                        • 11576
                        [QUOTE=iXe<30;3232499]
                        no idea, my odo. doesn't work
                        • iXe<30
                          • 143
                          bummer.... i think im gona go ahead with this instead of pulling my i motor for a refresh. thanks for the thread guys. Anyone close to pa have an eta block fs?...
                          Edit: woah sorry for the thread jack ill stop now..
                          • ÜberslowETA
                            • 190
                            This is great to hear! I have been staring at a complete lot of parts for a 731 head based swap. Im feelin motivated to jump on it.
                            OP...did you ever consider 19# injectors or an MAF?
                            • Gary Horneck
                              • May 2011
                              • 435
                              Two AutoX's later, and making quite an impression on the Street Prepared class. I now run in DSP, and have taken class twice, and a FTD in SP Sunday. Second run of the day on Sunday...
                              • e30trooper
                                • 11576
                                A small update on my car. Installed a 3.73 lsd last week and tracked the car on Sunday.
                                WOW , after all that work and then installing a proper gear ratio the car pulls great. With all season tires I can chirp 3rd gear all day long. On the track I couldn't get grip due to the tires. However on a uphill pull ( top of 2nd and mid 3rd gear ) i pulled about a car and half on a s2k. So mid range power is where its at. Im lovin it!
