325e motor mount Replacement
  • Mr. Tasty
    • Jul 2011
    • 3421
    So I have 3 out of 4 of the nuts off for replacing my motor mounts. The one giving me problems is the top passenger's side. Anyone have any tips to getting to that nut? I would rather not drop the subframe.
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
    • 37832
    The charcoal canister may be in the way, it's easy to move.
    I'd recommend a 1/2" ratchet with a long extension to get the motor mount nut.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • jeffnhiscars
      • Jun 2011
      • 6011
      Passenger side...its the exhaust manifold. Unbolt the heat shield on the mount and as mr325 suggested use a long extension (IIRC with a u-joint). A crowfoot might work as well if you have one.
      Alice the Time Capsule
        • 37832
        Woops! Should real better next time.
        Grover Beach, CA
        www.BimmerHeads.com
        • Mr. Tasty
          • Jul 2011
          • 3421
          damn, I tried just bending it back to the manifold. I really didn't want to have to take the shield off. Thanks.
          (Daily Driver)
          KW V2 Coilovers
          • jeffnhiscars
            • Jun 2011
            • 6011
            lol...learn to type too while you are at it :)
            "L" isnt even near "D" on my keyboard...wth...lol
            • jeffnhiscars
              • Jun 2011
              • 6011
              I'm talking about the aluminum shield that sits right on the mount to protect it from the exhaust...it's about 3x3..NOT the ones under your spark plugs.
              It may be different on your "e" but on my Cabrio there are 2 small bolts facing the rear that free up the heat shield. One is obvious and the other is hidden under the manifold and is easily reachable...as long as your hands arent meathooks
                • 37832
                I give up!
                Grover Beach, CA
                www.BimmerHeads.com
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  I give up!
                  Namaste
                  • Mr. Tasty
                    • Jul 2011
                    • 3421
                    yes, I bent the heat shield for the mount.
                    I didn't want to have to take it off. Thanks though
                    (Daily Driver)
                    KW V2 Coilovers
