Rotate rocker shaft arm in situ?
  • Mr_P
    • Jul 2012
    • 13
    So after picking up, having cleaned up and re installing (with new gaskets & bolts), a new (used) head, I pulled off the cover this evening to adjust the valve clearance as it was super noisy
    In the process of doing this I found all the valve clamps (the small black brackets over the valves) on the intake side had all come off (explains the noise!) - In trying to reinstall them, I have found the rocker arm shaft (where the slits they lock in to) is 180 degrees the wrong way... :(
    Is there a way to twist the shaft without removing the head (and having to replace the HG and bolts & timing belt again)?
    I doubt the shop that sold me the head or the engine workshop will take any responsibility either, and I should have checked - but they were all in place when I put it back in (most likely just sitting there but not locked in)
    Yes you can rotate the shaft to get it back where it should be. The locking piece at the front of the head must be missing to allow the shafts to rotate, so you'll need to fix that after getting the shafts back in place.
    • Mr_P
      • Jul 2012
      • 13
      Thanks for that - I havent checked, but I think this piece is missing - I couldnt rotate it on my own, but I havent taken to it vice vice grips & a cloth yet so hopefully that will work
      I can salvage the locking piece of my old head I hope
        Use vice grips and copper pads on the shaft.
        • Mr_P
          • Jul 2012
          • 13
          Vice grips and a cloth and it was easy, after I removed the oil gallery though as I couldnt turn the vice grips enough in place
          So job done :)
          I still have a horrible rattle/ticking from the engine somewhere and am slowly starting to think I may have over-tightened the timing belt :(
          • audiRS4ever
            • Jul 2014
            • 25
            What types of copper pads do you mean? Sorry for bringing this thread back from the dead, but I am having the same problem.
            • packratbimmer
              • Dec 2009
              • 1335
              He is saying to use copper to protect the shaft from scratching when you clamp the Vice-Grips. Any soft metal plate should work. Double thickness of beer can would work in a pinch.
              • digger
                • Nov 2005
                • 6148
                Short length of copper tube then cut it down the guts
                • audiRS4ever
                  • Jul 2014
                  • 25
                  No pun intended!
                  I picked up a couple little copper brackets on the way home from work and tried - am unable to get the damn thing to move. The copper doesn't want to grip the shaft no matter how hard I grip (or set vice to grip).
                  I also tried it with a piece of leather, but same deal. Can't get any traction on the metal.
                  There isn't any moment on the shaft as I backed all the rockers off the cam lobes, and I pulled the rubber stoppers from both sides too. There really shouldn't be anything preventing it from moving. Anyone having any further suggestions?
                  • audiRS4ever
                    • Jul 2014
                    • 25
                    Here are some pics - you can see my problem in the one (shafts need to be rotated to get the retaining key to fit), and my attempt at solving it in the other.
                    • 15Michaeljoseph
                      • Aug 2013
                      • 1693
                      How about a piece of old timing belt? (iirc I just used bare vise grips on a section of the shaft that doesn't get ridden on)
                      All your rockers are loose, and the locking piece is out... It ought to move.
                      Sent from my XT1064 using Tapatalk
                      (OO=[][]=OO) For Life
