Removal of intake manifold....stuck?
  • Mr. Burns
    • Aug 2011
    • 3516
    Have engine out if car, on engine stand.
    Removed all 12 bolts.
    I've done this twice before on other engine, and with a little effort came off effortlessly.
    Sucker won't budge. Am I missing something?
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
  • 5Toes
    • 9836
    Bitch tube?
    Just wiggle that fucker
    • Mr. Burns
      • Aug 2011
      • 3516
      Man, we hacked at it with crowbars and fat flathead screwdrivers and mallets.
      Broke the gasket on intake runners 1 and 6 but it's stuck on there good.
      Oh it's a IX engine...still a m20b25, but we all know they're redheaded style different....
      • SmokeE30
        • 1730
        so you have removed the tube under the minifold that goes down to the crankcase? are there any visibly bent studs?
        Shawn @ Bimmerbuddies
        Bimmerbuddies LLC
        717-388-1256
        2971a Roundtop Rd, Middletown PA 17057
        bimmerbuddiesllc@gmail.com
        • Mr. Burns
          • Aug 2011
          • 3516
          It's unhooked, not removed. Nothing visibly bent.
          I'm beginning to think the po usedjb weld or some insane gasket maker to get this thing to stick on...
          • SmokeE30
            • 1730
            by unhooked do you mean it is not touhing the intake manifold anymore because its spring loaded so even if you pull it down it will naturaly spring back up into its hole. and check on the gaskets you already damaged for traces of some sort of sealant
            Bimmerbuddies LLC
            717-388-1256
              • 34847
              Tube of death is my hunch.
              • Mr. Burns
                • Aug 2011
                • 3516
                The tube us dangling all slack. You're saying it has to be removed all together??? Didn't have to do that on previous engines....
                • SmokeE30
                  • 1730
                  just saying if you just pull it down the spring has a habbit of pushing it right back up into place, if you alread pulled it down its just a matter of pulling it up and out to have it off,
                  Bimmerbuddies LLC
                  717-388-1256
                  • 5Toes
                    • 9836
                    Maybe put some heat near the gaskets?
                    • Mr. Burns
                      • Aug 2011
                      • 3516
                      Thanks, we'll give that a try
                        The oil return tube has to be pushed down to the point that it is no longer in the intake manifold for the intake to come off. But even if the tube isn't disengaged the intake will move some back off the head. It really sounds like some sort of glue was used between the intake and head. Try driving a putty knife between the intake and head at multiple places.
                        • paperplane94
                          • Jul 2011
                          • 420
                          Bfh
                          • FLG
                            • Sep 2011
                            • 3165
                            If he used "right stuff" gasket maker....you'll be working at it for a looong time. Damn thing is like glue.
                            Sent from my Galaxy Nexus using Tapatalk 2
                            -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                              • 37834
                              Check to make sure the washers are also removed from the studs. Sometimes a washer can actually hold the manifold on, it's happened to me.
                              Grover Beach, California
                              BimmerHeads.com
