O.S seta pistons w/ b25 crank ?? can this be done
  • e30m20TurbO7
    • 1203
    if so what rods would i need to use in order to make this work
    let me know
  • e30m20TurbO7
    • 1203
    Anyone know this
    • Bretts85E30
      • 340
      Far as I know the seta bottom end is the same as a b25 bottom end its the head that's different which point I think seta rods should be ok but I'm just goin on hearsay
        • 37834
        This is all wrong.
        Super Eta crank and rods are the same as Eta parts. The Super Eta pistons are specific to the Super Eta, and the Super Eta engine uses the 885 head casting.
        Grover Beach, California
        BimmerHeads.com
        • digger
          • Nov 2005
          • 6215
          look at the logic
          take a seta and destroke it with b25 crank and piston goes 3mm down bore 81-75 / 2 = 3mm with eta/seta rod. try using a b25 rod +5mm and you are 2mm above the deck.
          this is not a good idea and not worth pursueing though in theory you could get either to work if you wanted
          • Bretts85E30
            • 340
            Ah I see then what read was wrong thats what I understood as to why the seta bottom was desirable for the head swap
              • 37834
              It's desirable for the 885 i head swap because the Super Eta engine was designed using the 885 head casting as well. The only difference is the Super Eta 885 head had a more mild cam and single valve springs.
              BimmerHeads.com
              • e30m20TurbO7
                • 1203
                Good info
                Another dumb question
                Do eta blocks have the same bore as b25 blocks
                  Originally posted by e30m20TurbO7
                  Good info
                  Yes
