dating an engine block
  • bmwstudent
    • Sep 2011
    • 1364
    The motor in question was supposed to be out of an 89 vert, engine number is stamped into block just above the oil pan on drivers side of engine. 24726629 I know the first number indicates it is an m20, the next three numbers indicate the engine serial number 472, the first 6 indicates it was built in austria, and that the last three numbers are supposed to indicate the production day 629. However the problem i'm having is that i don't know what the 629 indicates. Is it june 29th, is it the 629th day of engine production. I've got another block that has the last three digits as 029. There is no zero month, so that sort of kills my june 29th theory on the engine i'm asking about. And since this is supposed to be an 89 engine that sort of kills the 629th day of engine production idea, considering the m20 was in production for several years before 1989 and there are 365 days in a year. I've been searching but can't find any concrete info on the last three numbers. Any help would be appreciated, I'm trying to order main bearings for this engine and i know the date break for different bearings occurred in february of 88. I don't want to pay for the wrong ones.
    The locking notches in the block and bearing caps determine which bearings you need. Early production has a single 2.9mm notch and late production will have one or two 2.0mm notches and can have crescent shaped oil groves in the bearing cap. You can use the late bearings in an early block, but not vice versa.
    • mitchlevy7
      • Aug 2011
      • 672
      Read thread title and got the wrong idea.
      www.cp-e.com
      1989 Zinno 325i m52 turbo coupe
      2015 Ford Fiesta ST, Daily Driver.
      • drumad
        • Aug 2009
        • 1700
        I'm sad to say the same thing.
        2008 335i - n54b30
        1991 318i - m52b28
        1994 fzj80 - LAND CRUSHER
        • jeffnhiscars
          • Jun 2011
          • 6011
          +1
          My gut said "never"..but I'd date its sister
          Alice the Time Capsule
          • bmwstudent
            • Sep 2011
            • 1364
            Thanks, Jlevie. Your info is always helpful and not full of bull.
            • TobyB
              • 5296
              no, I wouldn't date a bull, either...
              t
