M20 Injectors - Why use m50?
If all you have is a chip it can go either way. 19# type II or type III. If all you have is a chip you will be fine with the M50 injectors too. Pretty much up to you.
Just shoot me a PM if you need a set.Comment
Thank you very much for your explanation. That was helpful. Again, not to hijack this thread but would swapping in the mentioned type III injectors into an ETA interfere with flow rate? Is this just a matter of plug and play or would any fine adjustments be needed? Any info appreciated!So yes, as long as the flow rate of the injectors stays the same (or corresponding changes are made to the tune which shorten the injector pulse widths when running larger injectors) then fuel efficiency will increase with better atomization since you are able to do more work with the same amount of fuel. It mainly comes down to the driver being able to take advantage of this though.Newb to all the things.Comment
There is a final matter to consider. The ETA run a low impedance system. The injectors I carry, and a lot of the "common" upgrades are designed for the more modern high impedance system. You cannot swap injectors across. Honestly for the ETA I either recommend a set of 19# type 3s to go with yuor 885 head swap (and all the "I" electronics that come with) - or a rebuild of the stock injectors. The ETA injectors actually flow pretty much the same as the M50 units.Thank you very much for your explanation. That was helpful. Again, not to hijack this thread but would swapping in the mentioned type III injectors into an ETA interfere with flow rate? Is this just a matter of plug and play or would any fine adjustments be needed? Any info appreciated!Comment
What would you say if I wanted to take advantage of the 4-hole designs, but I'm running a stock ETA motor? If you sell anything that could work, let me know.Newb to all the things.Comment
Well I will summarize here what i sent you via PM. The only upgrade I can think of is the injectors from certain early gen Porsches (944s I believe). They have 19# low impedance units inthe 4 cylinders.
I strongly recommend a rebuild for a stock ETA. You are not going to find any more power there I am afraid.
MaksimComment
Maksim
or rebuild stock units and use the 3.0 fpr off an I vs the 2.5 eta FPR ...voila you are close to 19# but do you have the need for it on an eta.....Comment
Hey guys I gotta revive this old thread.
I've had a intermittent check engine light (lambda) for the last couple of years now and I'm at the point of replacing the injectors. I can see a small fuel leak coming from the number 3 injector and there is an obvious smell of gas. In addition I'm getting poor gas mileage (about 17 mpg mixed).
I having a hard time understanding the information here it seems as though people are suggestion the 19lb over the 17lb and then ive been told by others to just have the origonal injectors rebuild. I would really like to go to a 4 pintle type III my current injectors are crazy loud.
My car is basically stock
eBay long tube headers to catless 2.5in out to stock muffler exhaust is my only performance mod.
What I'm looking for.
1 - fix my check engine light
2 - regain some mpg
3 - fix gas smell
4 - quieter injectorsComment
I bought and installed the M50 bosch injectors, 17lb, for my m20 (with chip) and feel it helped my performance and starts. One of the best upgrades I ever did.
This is where I got my rebuilt ones from.
http://www.ebay.com/itm/BMW-E36-M3-3...item2ed1d34377Comment
This seems like a very important piece of information. But when you say the ETA injectors flow generally the same, do you mean their numbers or their pattern?There is a final matter to consider. The ETA run a low impedance system. The injectors I carry, and a lot of the "common" upgrades are designed for the more modern high impedance system. You cannot swap injectors across. Honestly for the ETA I either recommend a set of 19# type 3s to go with yuor 885 head swap (and all the "I" electronics that come with) - or a rebuild of the stock injectors. The ETA injectors actually flow pretty much the same as the M50 units.Comment
So I want to purchase rebuilt injectors for my SuperEta with complete i head and internals.
What suits my engine the best?
Would that be what I need?
http://www.ebay.com/itm/1-YEAR-WARRA...2b9260&vxp=mtr1990 kashmir beige BMW e30 327i
1993 muggello rot BMW e36 M3 Gruppe A Euro
1990 GP weiss Porsche 964 C2
1997 schwarz II BMW e36 328iS supercharged
No those are far too big. They are 21lb.So I want to purchase rebuilt injectors for my SuperEta with complete i head and internals.
You want the 17lb M50/S50 injectors.Comment
