Need help!! car redlining when its not suppose to??
  • e30_OneLove
    • Sep 2011
    • 154
    So i have a 89 325is and recently my car has been redlining?
    Before i could reach high speeds but now ill reach 100mph and the rpm's will go from 5k to redline and the engine bogs out and i cant go any faster. Today it did it to me at 80mph and redlines again. Last time it did it twice and I had a really big back fire:(
    I dont know if its the transmission slipping or what could it be?
    BTW the car is automatic, and i swapped the engine from a 91 325i'
    If you guys can help me it would be great:D Thanks
    Are you hearing the engine speed actually increase to the redline, or does the tach go high without an increase in engine speed? The former would be a transmission problem. The latter would be a problem with the CPS, engine harness, or DME.
    • paperplane94
      • Jul 2011
      • 420
      slippage.
        If it is slippage, the transmission is about to quit working.
        • e30_OneLove
          • Sep 2011
          • 154
          yeah it doesn't increase speed just redlines and i loose speed and than it responds but there is no point on stepping on it cus it will do it again.
          Oh okay damm well perfect time to do a 5 speed swap, thanks guys.:D
          • TobyB
            • 5286
            you COULD check the trans fluid level before you throw it away...
            t
            • Bretts85E30
              • 340
              Yeah my trans lines seep so when the trans gets low after a few months it slips a Lil and I fill it back up and its just like new again
              • jeffnhiscars
                • Jun 2011
                • 6011
                So you knew when you posted this that the problem was a bad hose causing low fluid.
                You are not the OP..my bad !!
                Alice the Time Capsule
