e to i swap information please
  • low330
    • Apr 2011
    • 42
    I have a 1986 325es and it came with the 2.7 eta as I'm sure all of you know. However to make a long story short i spun a bearing and i got my hands on a 2.5 i motor out of a 91 325i which i think is motronic 1.1? I believe? Anyway I tore apart the motor and am going to (for the first time ever in 3 motor swaps ive been apart of) redo the bottom end. Any suggestions? And by redo I mean rod and main bearings, front and rear main seals, piston rings etc. Nothing crazy just want it to run. No stroker however may be in the future. But the main reason im posting this is to get any information on an E to I swap I've looked at strictlyeta.com, I've been on r3v looking and can't seem to find anything other than stroker build threads. I've heard that there are some wires and connecters to switch over. Which ones, i have no idea. Also I wanted to use my overflow from the eta, (i think i have better luck burping the cooling system with that system.) Are there any problems i should be aware of? I know the water pump is different and a coolant hose that runs from the rear of the block but any other information is greatly appreciated. One last thing anyone have a link to a diagram or a labeled picture of the I harness so i can label everything before assembly please and thank you for your time.
  • TobyB
    • 5250
    Search for 'C101'- that has the electronic details you need, assuming you got the ECU and motor harness. Which you want. There's a very good post with wires broken out
    by year. My addition is to remind you to check to make sure pin 20 doesn't have a
    greeen wire on the body side connecting to a red wire on the engine side...
    Otherwise, get an early i radiator and I think you're done. The early i used the same right-
    side reservoir and schtuff...
    Don't neglect to hone the bores when re- ringing....
    t
    • low330
      • Apr 2011
      • 42
      t
      I have the ecu and wiring harness do i still need to worry about "make sure pin 20 doesn't have a greeen wire on the body side connecting to a red wire on the engine side"even if the ecu motor and harness ALL came from the same car?
      and when you say early i radiator, like 88 - 89 or what years in particular?
      and most definitely with the honeing
      Thank you
      • Delraco
        • Jul 2010
        • 116
        My 86 eta had the C101 connector already therefore very little had to be done in the way of wiring other than a few splices for early style connectors on sensors. Also, pretty sure that a 91 325i is motronic 1.3.
        I'm not quite done with my swap over, but I kept the block from my 325es and replaced everything else with parts from a friend's 91 325is. Head, ecu, engine harness, cps,toothed crank pulley, spark plug wires, all intake/throttle components, thermostat housing, injector harness, fpr, injectors, exhaust, etc.
        1986 is one of those weirdo transitional years for e30s, so let's hope you already have the C101 connector.
        • low330
          • Apr 2011
          • 42
          So u pretty much did a stroker? And what is this c101 connector? Is it the connector off the main harness to the ecu or what? Everyone keeps telling me about this connector I'm so lost. What if I don't have it? What's the issue then?
            C101 is the connector between the engine harness and the car's wiring, located next to the fuse box. All E30's have a C101 with early production having a square connector and late production having a round connector.
            • mbonanni
              • Sep 2011
              • 6236
              I am kind of in the same situation.
              I have a 1987 325 and I have a 1989 m20b25 with 1989 harness. Do I need to cut/splice any wires, or can I just plug the harness up?
              Sorry to thread jack.
              • low330
                • Apr 2011
                • 42
                UPDATE:
                Okay so less then 5 minutes ago I decided to do a stroker. Need information please!
                I know I'm planning on doing the eta bottom end with a 885 head, I harness, I intake and I injectors. That's all I know rite now. Any other information is greatly appreciated.
                • dougie30
                  • Apr 2012
                  • 1708
                  I am in the same exact boat as you guys, i have an 86es and plan on doing a e to i swap so could we possibly keep this thread going? like if my fuse box has the square connector what do i do then?
                  M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
                  • Cronopoulos
                    • Jul 2011
                    • 2187
                    Guys,
                    Check out this thread and read it thoroughly as it should answer most of your questions -
                    Project log -- DIRTY 30
                    2.7i * Megasquirt tuned * E85 powered
                    • low330
                      • Apr 2011
                      • 42
                      Originally posted by Cronopoulos
                      Guys,
                      http://www.r3vlimited.com/BOARD/show...ap+information
                      everyone keeps linkin me to this and its not helping me ive looked at it like 100 times and it seems to skip over what im trying to do. 86 325es with an 91 325i 1.3 motronic harness.
                      • dougie30
                        • Apr 2012
                        • 1708
                        exactly my same problem....
                        • Cronopoulos
                          • Jul 2011
                          • 2187
                          PM me dudes
                          • dougie30
                            • Apr 2012
                            • 1708
                            also check out my E to I wiring thread in this forum, a fellow member just gave me some very helpful info to the whole wiring aspect, because we are literally doing the exact same engine swap.
                            • dougie30
                              • Apr 2012
                              • 1708
                              OP ever come across more info??
