325i misc wire connector?
  • Smrtpunk
    • Sep 2011
    • 95
    Do some 325i cars have a cold start injector?
    The reason I ask is im doing a 2.7 Swap in an 86 325e and I've collected parts from a few different cars to make the swap work.
    The head/intake/sensors are from a 90 Automatic 325i. The Wiring harness however is from a 87 325i.
    The guy who sold me the harness labelled everything really well and one of the plugs that I am unable to find a sensor for is labled "lower fuel rail." I've looked high and low on the car and am unable to find the sensor where this plug could fit into it's a very short two prong connector off the main harness right under the intake.
    I haven't tried to start the car as I'm still waiting on the exhaust and some other stuff, so maybe it will work without it I just though it was odd that I couldn't find anything to plug it into.
    Thanks
    No M20B25 engine ever had a cold start injector.
    The loose connector you have could be for the evaporative control valve.
      • 34844
      that's what it sounds like to me.
      • Smrtpunk
        • Sep 2011
        • 95
        Can anyone find a picture of what the Evap control valve looks like? Is it involved with the A/C system?
          The evaporative control valve goes between the nipple on the bottom of the throttle body and the charcoal canister.
            • 34844
            no, it recycles gasoline vapors from your fuel tank that would normally evaporate (tanks have to be ventilated due to thermo expansion).
            • vpilarrt
              • Jun 2006
              • 2096
              Valve is #19, canister is #15 (attached to the left wheel well in the engine bay).
              • Smrtpunk
                • Sep 2011
                • 95
                Originally posted by vpilarrt
                http://bmwfans.info/parts/catalog/E3...bon_container/
                Thanks for the diagram, I know what this is now!
