is my cluster wrong or is my car chipped?
  • kman_e30
    • May 2007
    • 573
    untill today my rpm gauge has never worked since my swap last year, the rev limit on car is at 7000 rpm! i thought stock its like 6500 rpm or something like that. i opened my ecu but i didnt see anything aftermarket, or at least i couldnt tell. could it be because i have a 318 cluster instead of a 325i cluster, or do i have some type of nameless chip in my ecu?
    84 318i drift car
    04 mk4 gti 1.8t
    96 e320
    63 plymouth valiant
    A cluster (or coding plug) from a four cylinder car in a six cylinder car will result in the tach reading high by a factor of 3/2.
    • Gregs///M
      • Mar 2012
      • 2459
      You can't use a 318i cluster in a 6 cylinder car unless you want the tach to read high. If you have a coding chip cluster, you can just swap the coding plug from a 6 cylinder car.
      I have a 6 cylinder coding chip if you need it. PM if so.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • SmokeE30
        • 1730
        as stated its the fact that its a 318 cluster, get the correct cluster or coding chip, although if you have a m42 cluster with an m20 it will wrap the tach down to the mpg guage which looks nasty but its just because its counting for a 4cyl not a 6cyl its not actualy reving that high.
        Shawn @ Bimmerbuddies
        Bimmerbuddies LLC
        717-388-1256
        2971a Roundtop Rd, Middletown PA 17057
        bimmerbuddiesllc@gmail.com
