cxracing radiator or bimmerworld high capacity radiator?!
  • dnguyen1963
    • Nov 2011
    • 2651
    Originally posted by Alexis Jung
    I have the E36 mishimoto radiator in my M3. It required some trimming of the stock fan shroud...more than I care to think about.
    Does the CX Racing one require Any modification? Even a little trimming to the shroud? I like the idea of never having to replace my radiator again.
    No trimming at all...direct fit for my car.
    • bangsquad
      • Jul 2012
      • 8
      My car has a brand new thermostat and water pump it still over heats it creeps up The half way mark after standing still for 5 to 10 min also one time I came back from a 20 min drive and all the coolant leaked no broken hoses
      • TurboJake
        • 3780
        Half way is not overheating...
        Leave Me Transaction Feedback
          • 37833
          The car is supposed to run at half temp when sitting idle.
          If your coolant is leaking out... YOU HAVE A LEAK. Find it and fix it.
          Grover Beach, California
          BimmerHeads.com
          • BMWManiac
            • Dec 2010
            • 1091
            You verified that all the coolant hoses, heater hoses do not leak? Where was the leak? You filled it with coolant, turned on your heat to max? If there isn't a "leak" per say, but all the coolant is gone, then the coolant was filling your heater core.
            If you did have a leak, there are a couple places....t-stat housing (missing any nuts?), water pump gasket.....look for white "splatter" around the engine.
            1997 Artic Silver M3
            CES GT4094r 651hp/615tq @ 24 psi
            • bangsquad
              • Jul 2012
              • 8
              i said creeps up the half way mark........ it goess past the half way mark sometimes even passed the 3rd mark
