Headgasket/Bolts/T Belt/ Water Pump/etc
  • providence
    • 154
    I've got my M20 stripped and mounted on a stand.. just ordered as much as I could think of in terms of 'while you're in there' parts including cylinder head and crankcase gasket sets. So I'm doing headgasket, water pump, tensioner, belt, head bolts, rear crank seal.. I know I won't be able to replace every last thing (i.e. things like valve stem seals). I am looking for advice as far as what I can reasonably expect to be able to replace during this project without too much trouble.. looking at the Bentley I'm fairly sure I'm not gonna loosen that 22mm crankshaft bolt, but given that I have some time and access with the engine on a stand and a full set of seals- what's a a good list of seals/gaskets I can get to and replace from these sets, and any advice pertaining to specific ones. Thanks much.
  • paperplane94
    • Jul 2011
    • 420
    intake/exhaust mani gaskets
    injector o-rings
    B*tch tube o-ring
    TB gasket
    VC gasket
    dipstick seals top and bottom of tube
    rocker shaft plugs
    TB cooling cork gasket
    What else?
    • jeffnhiscars
      • Jun 2011
      • 6010
      Why did you pull the engine in the 1st place and why would you go to all that effort and not replace something like the valve seals ?
      Alice the Time Capsule
      • BMW_325i
        • 61
        Parts touched during TB / WP change
        Water pump bolts and wave washers
        Coolant block drain bolt crush washer
        Gasket for Front Engine Cover (timing cover lower)
        Valve Adjusting Eccentrics – if worn
        O-Ring for Oil Filter Housing to Block
        Seal Kit for Oil Filter Housing
        Camshaft Seal
        Cam Flange O-Ring
        Intermediate Shaft Seal
        Crankshaft seal, front
        Holding Clip, Front of Timing Belt Cover – become brittle over time and break easily, hold sensor wire(s) away from belts
        Radiator hoses and clamps – depending on condition
        Dizzy cap and rotor – depending on condition
        3 x 3mm allen bolts for dizzy rotor – easy to strip
        a/c, p/s and alternator belts – unless not cracked
        Other parts much easier to replace while engine is out
        voltage regulator - much easier with alternator removed
        injector refurb kit / new injectors
        fuel hoses
        1988 Lachssilber E30 325i sedan.
        Factory fit-out: manual; SILBER LEDER; M SPORT SUSPENSION.
        Modifications so far: Miller MAF + 19# ECU; Ford 19# Design 3 injectors; IE adjustable FPR; KAMotors CF airbox; IM MTX-L; EBC Greenstuff.
        Retired - '83 Arctic Blue E28 528i powered by M30B32
        • paperplane94
          • Jul 2011
          • 420
          ^YES Fasteners!
          • providence
            • 154
            Thanks for the input on this. Engine is a spare I had bought a few years ago that does not need much. Broke a T-Belt, pulled that engine. Getting this one ready to put back in my car. Minimal budget but I generally work with as many new parts (fasteners for sure) as I can afford. Things like valve stem seals, removing the crank bolt.. do I really need all the special tools? Advice is appreciated.. I would love to use every last piece of these upper and lower gasket sets, just trying to get an idea of how in depth to get. I have a couple weeks to get the car back on the road basically and 90% of the new parts on hand.
            • jeffnhiscars
              • Jun 2011
              • 6010
              Im expecting 12 valve seals to be delivered today so this should be current :-)
              Elring OEM for 69c@. No special tools required.
