replacing #1 rocker
  • bastianshaw
    • Jan 2007
    • 2210
    replacing #1 rocker
    So I just bought a vert last night, was running like shit. Has a broken rocker arm on the cylinder closest the radiator.
    Should I pull the head and fix or can i remove radiator and motor mounts and tilt the motor to pull the rocker shaft.
    I need help deciding if I should just part out or fix; if I can NOT do the head gasket and fix her for the cost of a rocker arm ill have a new vert.
  • UserError
    • 86
    on #1 and #6, you can replace the broken rocker without moving the engine, just pull out the rocker shaft plugs and tap it backward/forward. On 2-5, you'll have to pull the head.
    • bastianshaw
      • Jan 2007
      • 2210
      that is very good news...
      Also seems like the piston would be htting the valve right?
      bent valve damaged piston?
      • downforce22
        • Aug 2009
        • 3192
        Not true. :ohsnap:
        I just replaced #1 rocker on intake by sliding the rocker shaft out front toward the radiator removing all 6 rockers to get to number 1. I replaced a couple worn ones on cylinders 5 and 4 in the process.
        You can remove the radiator and should be able to move the engine around to get the shaft out. I also did it with the timing gear and belt on, just removed the plastic cover on the timing gear. This was on a 325iX so the motor mounts may be slightly different placement but the principal is the same. It took me an afternoon. I would suggest going to a junkyard and getting a spare head if you can for cheap so you know how the rocker/clips/rocker shafts go together and practicing removing the rockers on the junk head before doing it on yours.
        Here is a simple DIY http://e30technic.com/forum/showthre...adjustment-DIY
        I would suggest a few things.
        -If you have the timing belt on you can turn the cam without damaging anything. This allows you to remove the rocker retaining clips and slide them off the cam which lessens the force on the rocker shaft allowing you to pull/slide it out easier.
        -Be careful not to mushroom the shaft as you tap it out of place. I used a quarter inch drive extension, it worked great.
        -While you have the fan off and finish the rocker do the valve adjustment as you can turn the cam with the crank without moving the car/lifting the car.
        -The most annoying thing was having to drain some of the coolant hoses/radiator and fit it back together with coolant dripping on you. I didn't drain the block of coolant and suggest you don't either.
        It seems intimidating, just be careful and pay attention and your vert will be running smoothly once again.
        And as for your question above, no the rocker breaks and the spring returns the valve to closed position. The rocker is therefore a fail-safe that protects the engine from further damage. The rockers were designed to break where they do to protect the engine from damaging itself.
        • bastianshaw
          • Jan 2007
          • 2210
          Originally posted by downforce22
          Not true. :ohsnap:
          NICE POST
          thanks
          • bastianshaw
            • Jan 2007
            • 2210
            Ok i pulled the VC and its the #6 exhaust rocker arm:
            now what? im picking up a busted head tomorrow to practice on and to get another rocker arm.
            can you bend a rod driving w a valve closed?
            • SpecM
              • Oct 2005
              • 4531
              That's cylinder 1
              Sent from my Vortex using Tapatalk 2
              1989 cirrisblau-metallic 325i
                • 37828
                A broken rocker won't do any damage to a valve or a rod.
                I wouldn't recommend driving it though unless you disconnect the injector on that cylinder.
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • bastianshaw
                  • Jan 2007
                  • 2210
                  this idea intrigues me...
                  • jeffnhiscars
                    • Jun 2011
                    • 6010
                    I'm missing something here. How do you drive the shaft anywhere with the head being an inch from the firewall ?
                    Alice the Time Capsule
                    • downforce22
                      • Aug 2009
                      • 3192
                      Once you pull the head plug(the black rubber pieces that seal the head) you have enough room to fit a 13mm socket in the space and tap it out a bit. Then you can fit the entension or two in there to tap it further until you can slide it out by hand. Make sure to clean the grease off as that helps sliding it out.
                      If you turn the camshaft so cylinder 6 is engaged all 5 others are not and you can tap it out. Thanks why keeping the belt on is helpful because it allows you to turn the cam without throwing off the timing and damaging the engine. There is a good write up here: (you need to take off the cam bolt so you can take off the rotor piece, but the cam gear stays held in place. You do this so you can slide the rocker shaft out between the cam gear with the Tbelt still on. Remember to but the bolt back on and only turn it clockwise when trying to turn the cam)
                      • jeffnhiscars
                        • Jun 2011
                        • 6010
                        http://www.e30zone.net/e30zonewiki/i..._Cylinder_Head
                        Having just reman'ed & installed a replacement head after the PO broke a timing belt I know how to remove rocker shafts.
                        The OP specifically mentioned cyl 1 rockers with the head attached which would require driving the shaft towards the firewall which I see as not possible. That was the basis of my question which remains open.
                        • downforce22
                          • Aug 2009
                          • 3192
                          True, what I am saying is you must remove all 6 rockers to get to that cylinder's rocker by sliding the shaft out the front of the car. It is obviously not possible to slide the shaft through the firewall, there is not enough room for that. Hence my posts above with the procedure to remove them all. It really isn't hard with the head on the car.
                          • jeffnhiscars
                            • Jun 2011
                            • 6010
                            Since we agree you can't drive the rocker shaft to the rear with the head on that leaves driving it towards the front as per above. Are you saying you can tap a socket and or extension from the rear of the head when its still on the car ?
                            • peytonracer4
                              • May 2011
                              • 524
                              how common are broken rocker arms on the m20's? i've heard of this before.
