Shave my head
  • CabbE30
    • Aug 2009
    • 2358
    Shave my head
    Redoing the headgasket, How much do I need to get shaved off when the machine shop is resurfacing my head?
    Engine: 1991 M20B25
    Thanks guys.
  • tinkwithanr
    • Jun 2010
    • 377
    As much as it takes to get it flat again. It also depends on if it has been machined in the past. There is a limit after which you can't take anymore material off.
    Tinker Engineering - 2014
    Mica - 2000 BMW 323i - The one that started it all
    Fiona - 1975 BMW 2002 - The Definition of Project Creep
    Heidi - 1988 BMW M5 - The piece of BMW history
    Silvia - 2013 Subaru WRX - Stock, for now
    • jeffnhiscars
      • Jun 2011
      • 6011
      There are 2 dimples on the face of the head that are actually depth gauges so as long as they haven't been milled off, it's fine.
      Alice the Time Capsule
      • F34R
        sLaughter
        • 12376
        I have noticed with the last two heads that it is under 4 thousands. Just had mine done(picked up today) removed 2ths. It had 108k on it though. I am sure with higher miles it might need more. Seen a few with 10ths stamped(246k on it).
        Instagram: @BWeissLeather
        Current cars:
        ~ '87 325 M30B35 swap
        ~ '87 535
        ~ 01 540 Msport 6spd
        ~ '06 X5 4.8is
        • CabbE30
          • Aug 2009
          • 2358
          Thanks for the help guys, I'll bury my nose in the Bentley & see if I can find the max limit.
          What did it run you? ($)
          • 5Toes
            • 9836
            I had my head machined and all the studs tapped to clean them up, and had it hot tanked (well the aluminium safe hot tanking thing) for $55 with tax
              • 37833
              Why do you want to shave it to the limit? If it ever needs to come off again you won't be able to have it decked and will need to find another head. Just have it decked normally to get it flat.
              Grover Beach, California
              BimmerHeads.com
              • CabbE30
                • Aug 2009
                • 2358
                I was just looking so that I knew what it was, I didn't plan on having it decked to the max. I didn't want to take it to the shop without any knowledge.
                • CabbE30
                  • Aug 2009
                  • 2358
                  I can't get my Cam sprocket off. any tips??
                  • lcoleman
                    • Jan 2009
                    • 331
                    did you take the belt off already? It's much easier when you can hold the crank bolt and break the cam loose. Obviously replace the belt after, but you're doing that anyway....;)
                    • Balleristic31
                      • Aug 2009
                      • 4198
                      Impact gun with the head off the car
                      -NICK
                        • 37833
                        Electric impact, invest in one. ;)
                        BimmerHeads.com
