how often do you do valve adjustments?
  • peytonracer4
    • May 2011
    • 524
    a have a lifter tick noise that increases speed with rpm but doesn't increase in volume. i'm guessing it's because i need a valve adjustment.
    how often does this need done on the m20? what do i need to do it? some special shims like on the e46 m3? those are expensive
  • 5Toes
    • 9836
    Its very easy, just need a set of feeler gauges. Pull the valve cover and stick the gauge (.012 inches is what I like) between the cam lobe and the rocker.
    You can also place it between the rocker and the top of the valve, but on the cam I find way easier.
    good article over on e30.de how to do it
    • noid
      • 1535
      I recently did a valve adjustment on mine and put this together:
      M20 E30 engines are flat-tappet engines that require periodic valve adjustments. The beloved and distinctive sound of M20 ticking, especially when cold, is due to the flat-tappet design. Reasons to adjust your valves include increased compression (as both intake and exhaust valves fully close), improved fuel economy, and overall enhanced performance. Remove the valve cover
      Its cheap, you just need a new valve cover gasket, and rubber shaft plugs (very cheap). Only "special" tool you need is a .010" = .254mm feeler gauge.
      Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
      Your resource to tools and tips: www.rtstools.com
      • peytonracer4
        • May 2011
        • 524
        Ah ok cool. I have a feeler gauge thing so that should work. Just very recently put a valve cover on so I should be good on reusing it yes? Less than 500 miles ago or so.
        Also still wondering about my original question, how often does it actually need done? Just checked every time I do a timing belt?
        • smooth
          • Apr 2005
          • 1940
          your valve cover gasket should be good on reusing but waiting until you change your timing belt is way too long on an m20.
          you do your timing belt every 60,000 or four years, whichever comes first.
          I believe the interval for valve adjustments is 15,000 but even that is kind of long. I did mine every 10,000 (every other oil change makes it easy to remember).
          Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
          • jeffnhiscars
            • Jun 2011
            • 6010
            Timing belt is 4 yrs\60k and I believe the recommended valve adjustment interval is 15k\1 yr. Many prefer to do it at 10k..and an M20 doesnt have lifters :-)
            LOL..I hear an echo in here
            Alice the Time Capsule
            • DooDanE30
              • Nov 2011
              • 683
              super easy to do a moron could do it. there is also a video on youtube of a guy adjusting his m20 and he takes you pretty much step by step.
              • E30nub1
                • 402
                did mine yesterday :) yeah that vid taught me a cool trick about adjusting them from the rear of the valve as opposed to the front..
                sigpic"God made cars to be RWD and standard"
                • CabbE30
                  • Aug 2009
                  • 2358
                  I prefer to adjust my valves between the rocker and the valve itself. Different strokes...
                  • E30nub1
                    • 402
                    i prefer that was as well but on the rears its saves time..and as i have done both ways.. i can't tell a difference in either way..but i agree...eventually ill just get the tool and won't deal with it..lol
                    • dnguyen1963
                      • Nov 2011
                      • 2648
                      Bavauto sells a whistle that you can plug into the sparkplug hole to find TDC (it stops whistling the the piston is all the way to the top). It makes adjusting the valves easy.
                      • u3b3rg33k
                        • Jan 2010
                        • 2452
                        Pretty sure if you use a .012" gauge between the cam and follower, you're setting the clearance too wide. that's the size for doing it between the eccentric and the valve stem.
                        Ich gehöre nicht zur Baader-Meinhof Gruppe
                        Originally posted by Top Gear
                        Just imagine waking up and remembering you're Mexican.
                        Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
                        • paperplane94
                          • Jul 2011
                          • 420
                          Nope^
                          The gap between the rocker eccentric and the valve stem is .010 thousandths of an inch.
                          The question now: What is the gap supposed to be between the cam and the rocker????
                          Bigger? Smaller? The same?
                          • jeffnhiscars
                            • Jun 2011
                            • 6010
                            Originally posted by paperplane94
                            Nope^
                            • 5Toes
                              • 9836
                              The space between the cam and the rocker is the same as between the cam rocker and the valve is the same... thats why you can wiggle a rocker back and forth against the cam and the valve.. then when the cam lobe rotates around it takes up the slack and opens the valve.
                              From e30.de
                              "On M20 (320i, 323i, 325e, 325i), it has the valve clearance proved contrary to BMW specifications (0.25 mm) to adjust a little looser. i.e. 0.30 mm inlet and outlet side. This provides a more stable idle (especially when 320i) and some fuel zigere performance. The clickers the valves becomes barely noticeable louder, the measure is worthwhile in any case."
                              The germans on their m20s know their shit hardcore and this is how they do it...
