how often do you do valve adjustments?
  • u3b3rg33k
    • Jan 2010
    • 2452
    Originally posted by 5Toes
    The cam between the cam and the rocker is the same... thats why you can wiggle a rocker back and forth against the cam and the valve.. then when the lobe rotates around it takes up the slack and opens the valve.
    I don't think you said what you meant to say, and I don't want to put words in your mouth.
    Ich gehöre nicht zur Baader-Meinhof Gruppe
    Originally posted by Top Gear
    Just imagine waking up and remembering you're Mexican.
    Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
    • Herr Faust Schinken
      • Feb 2012
      • 3580
      Every 2-3 oil changes so about 8-12k miles it doesn't cost anything to do a valve adjustment so I don't see why you wouldn't do it fairly often
      88 325is Five Speed
      Lachssilber
      • 5Toes
        • 9836
        Just edited it. Thanks for catching my mistake :)
        • u3b3rg33k
          • Jan 2010
          • 2452
          OK, now I can argue with you ;)
          the space doesn't have to be the same if one side is longer than the other - they'll be proportional, but not equal.
          So you could still have the play, but if you did the adjustment with the feeler gauge in the "wrong" place, you'd be setting the wrong clearance.
          did that make sense?
          • jeffnhiscars
            • Jun 2011
            • 6010
            Before I could write out my disagreement with this, I decided it was probably correct.
            Adjust to .010 then put a .005 on the cam side and measure the gap on the valve side..then let us know :D
            Alice the Time Capsule
            • u3b3rg33k
              • Jan 2010
              • 2452
              Well I'm not saying its 2:1, but I don't think it's 1:1. I thought I read somewhere once that cam side adjustments were somewhere around .009" but I can't seem to find it for reference.
              • 5Toes
                • 9836
                I dont see how they would be different, but okay..?
                • u3b3rg33k
                  • Jan 2010
                  • 2452
                  X1 > X2
                  like so:
                  if one side is longer, moving short side x amount moves long side y amount.
                  • dnguyen1963
                    • Nov 2011
                    • 2648
                    You guys have way too much time!
                    • 5Toes
                      • 9836
                      Well if somebody figures out the ratio, that would be sick.
                      I find it much easier to get an accurate adjustment when using the feeler against the cam. Plus it doesnt bend the shit out of your feeler gauge!
                      • dnguyen1963
                        • Nov 2011
                        • 2648
                        Angled feeler gauge is cheap, 5toes.
                        • u3b3rg33k
                          • Jan 2010
                          • 2452
                          Funny story, I once did a valve adjustment with a can of herring:
                          I'd suggest you adjust them cold, with a herring can lid.
                          Very simple to do:
                          1: Misplace your feeler gauges
                          2: get angry
                          3: find micrometer
                          4: measure stuff until you find a .010" object
                          5: cut the herring can tab into a rectangle
                          6: adjust valves
                          for those interested:
                          • dnguyen1963
                            • Nov 2011
                            • 2648
                            No shit, but seriously angled feeler gauge is less than $5 at HF. But, I guess you can eat Herring Fillets and adjust the valves afterward. It's a toss-up.
                            • rasputin
                              • Sep 2012
                              • 149
                              Originally posted by dnguyen1963
                              Bavauto sells a whistle that you can plug into the sparkplug hole to find TDC (it stops whistling the the piston is all the way to the top). It makes adjusting the valves easy.
                              my screw driver does the same thing.
                              • 5Toes
                                • 9836
                                Angled feeler gauges help, but still ti is hard to get it in the right spot and get the "pull" consistent.. for me anyways
