Yay valvetrain failure.
  • AwakenNoMore
    • Dec 2010
    • 1291
    #31
    Originally posted by Tisoc
    How did you clean the block surface? Looks supah clean
    brass wire wheel brush on a drill, removes old gasket gunk without removing any material from the block, also used it to clean all the carbon off the valves.
    Originally posted by offsetmotorwerks
    Great build Cant wait to see the video of it running. Took a second glance at the shark face.... loving it haha.
    Yeah Its just sharpie'd on for now, will get painted on soon.
    1991 325i - "Scambles" The Daily Driven lightly modded.
    1988 Mazda RX-7 TII "Mako" The Free Dorito
    bacon by Jared Laabs, on Flickr
    • AwakenNoMore
      • Dec 2010
      • 1291
      #32
      I DON'T KNOW WHICH ONE GOES WHERE!?
      • EatsHondas
        • Sep 2012
        • 404
        #33
        If you're standing in front of the car looking into the bay, the CPS goes on the left. The other connector is a the pulse generator that attaches to the number 6 plug wire and it goes on the right. They both plug into the harness under the diagnostic port by the dipstick.
        1989 325i Lachssilber Sedan
        5-Speed Swapped
        M30B35 Swapped
        MegaSquirt MS3X
        1987 325i Lachssilber Sedan
        260k OEM Automatic Daily Baby
        • AwakenNoMore
          • Dec 2010
          • 1291
          #34
          Don't happen to have the colors of the actual wires do you?
          • z122643
            • Aug 2011
            • 286
            #35
            [/SIGPIC]"we are so totally screwed!"
            • FLG
              • Sep 2011
              • 3165
              #36
              If you mix em up the only thing that will happen is the car won't start. Just guess.
              Sent from my Galaxy Nexus using Tapatalk 2
              -Build http://www.r3vlimited.com/board/showthread.php?t=295277
              • AwakenNoMore
                • Dec 2010
                • 1291
                #37
                Done-ish started up perfect after a jump. Still need to bleed coolant and a few other small things.
                A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
                • AwakenNoMore
                  • Dec 2010
                  • 1291
                  #38
                  Drove to work tonight, worried entire time about coolant bubbles, but no issues, car ran great. Now time to take care of EVERYTHING ELSE.
                  • EatsHondas
                    • Sep 2012
                    • 404
                    #39
                    e30 ownership in a nutshell, brother. Grats on the repair!
                    5-Speed Swapped
                    M30B35 Swapped
                    MegaSquirt MS3X
                    • AwakenNoMore
                      • Dec 2010
                      • 1291
                      #40
                      Thanks lol. All things considered, its still far less headache than any of the RX-7's I owned. Steering and suspension are next.
                      • EatsHondas
                        • Sep 2012
                        • 404
                        #41
                        What makes RX-7's more of a pain? I'm curious, never really worked on any car as in-depth as my e30. Don't you have more bay space with the 13B?
                        Same with mine. I have control arms, m3 bushings, and tie rods sitting in the garage, haven't had time to install them yet.
                        5-Speed Swapped
                        M30B35 Swapped
                        MegaSquirt MS3X
                        • AwakenNoMore
                          • Dec 2010
                          • 1291
                          #42
                          If you cook a rotary engine, its a full rebuild, not just yanking the head. They are much more sensitive to overheating. amongst many flaws.
                          • EatsHondas
                            • Sep 2012
                            • 404
                            #43
                            Makes sense, didn't think about that.
                            5-Speed Swapped
                            M30B35 Swapped
                            MegaSquirt MS3X
                            • e21jps
                              • Aug 2011
                              • 44
                              #44
                              tip for anyone setting valve clearance
                              set the feeler gauge on the cam not the valve as the eccentric often digs a little hollow in the valve stem then the feeler gauge sits across the hollow and gives a much wider setting and they clatter, BUT!!! if you do it from the cam the setting should be 007" not 010" because of the rocker ratio.
                              I sell ITB's and performance parts www.racehead.com.au
                              e21 race car m20 power! 293Whp atmo 2.9
                              details here http://e21jps.webs.com
                              drive by video http://www.youtube.com/watch?v=kOdPbErYlho
                              incar race http://www.youtube.com/watch?v=sbr0ZCmjsYM
                              incar video http://www.youtube.com/watch?v=aQyvDR-B00A
                              drag racing http://www.youtube.com/watch?v=7XmznH6PND4
                              • AwakenNoMore
                                • Dec 2010
                                • 1291
                                #45
                                ^ I'll keep this in mind when I re-adjust mine. Thanks for the tip!
