Charcoal Canister Purge valve P/N?
  • blocke
    • 1305
    Does anyone know the Part Number for this thing? I cannot find emissions related stuff on real OEM at all.
    Mine has a tear where it connects to the TB. I tired to take a pic with my phone, but its tough to make out.
    It has vac hoses connected to the TB and the charcoal canister, and then a connector that goes into the same loom as the TPS sensor.
    Its pictured in the Bentley section 6-16
    Anyone know the Part Number?
    Parts Wanted
    The Never-ending Resto Mod
  • E30-325iS
    • Sep 2011
    • 191
    I've got one some where, I'll see if I can find it tonight and get the part number.
    • blocke
      • 1305
      Thanks! I appreciate it
      Parts Wanted
      • blocke
        • 1305
        Wait..looks like Real OEM calls it something different.
        Is this it? http://www.realoem.com/bmw/showparts...07&hg=16&fg=10
        If so, fuck that. $165 for this thing? Can I just bypass it and plug the ports on the TB?
        Parts Wanted
        • E30-325iS
          • Sep 2011
          • 191
          The Bosch part number on the valve is 0280142150. The rubber hose that connects it to the TB has part number 1012552-4. If that rubber part is all that is broken you can just pull it off the valve and replace it with a piece of 6mm Id fuel hose, or you can remove it and plug the TB.
          • dougie30
            • Apr 2012
            • 1708
            i was wondering the same thing because my canister was rusted and where the hose connected acctually snapped the metal on the canister.
            so could i just find a junkyard one and replace it??
            M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
              • 34834
              you can use pretty much any 2-wire bosch PWM purge valve from the E30 era to nearly present day. go to a junkyard and find one off a VW jetta or something
