Am I Leaking Oil From the Head Gasket?
  • ClayW
    • Apr 2011
    • 377
    I seem to be leaking oil from somewhere near the front passenger side of the head on the M20 in my 91 325i. Is it possible that I'm leaking from the head gasket? Or is there a more likely leak point that I'm missing?
    1987 325e Commuter Project Blog
    1967 1600 Project Blog: www.TX02.blogspot.com
    The cam seal is a possibility for oil in that area.
    • SeatTime
      • Nov 2012
      • 23
      Not sure where the oil feed is, but there is a high pressure oil feed through the head gasket. It could leak.
      • Ginsterman98
        • Dec 2012
        • 89
        M20's are known to get external head gaskets leaks. They also like to leak back by cyl 6. Could be the cause.
        84 318, 86 325ES, 85 325E. 89 325IS,
        89 BMW 325is Turbo - 8.02@85mph 1/8th
        90 VW Golf, 01 VW TDI Jetta
        98 VW GTI VR6 - 11.679@117.58mph Timeslip
        96 VW GTI VR6 - 7.63@97mph
        www.lugtronic.com
        • K1CKBAC
          • 306
          It's possible. But can also be from cam seal area as mentioned above. I got the same problem but will look at the cam seal area first.
          My expectation is an immediate 5 speed swap. Autos suck more than a 50 year old whore.
          • Ginsterman98
            • Dec 2012
            • 89
            OP, just pull the cap, rotor and the dust cover and look into the timing belt area for evidence of oil.
            www.lugtronic.com
            • dougie30
              • Apr 2012
              • 1708
              Wipe it down with a rag, drive around for a while and see if it is still clean around the gasket or not
              M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
              • uuc328
                • Dec 2012
                • 85
                +1 head gasket
                mine leaks in the same spot. cam area was dry at my last timing belt change.
                • ClayW
                  • Apr 2011
                  • 377
                  After further investigation, it seems to be coming from the cam seal.
                  Out of curiosity, if it is the head gasket also, this means that I need to replace the head gasket along with new head bolts, correct? Am I missing anything?
                  • JCarp90
                    • Feb 2011
                    • 1759
                    Check the rocker shaft plugs. I had oil in the same spot after a full rebuild and it was just those damn things.
                    • ClayW
                      • Apr 2011
                      • 377
                      Good idea. I wasn't aware of what they were or their location. I will check them ASAP.
                      Thanks for the tip!
                      • SpecM
                        • Oct 2005
                        • 4531
                        and if it is, get the rocker plugs at the BMW dealer. they are only like $0.50 more each and other brands seem to leak more (for me)
                        1989 cirrisblau-metallic 325i
                        • 603Racing
                          • Dec 2010
                          • 612
                          If it is the headgasket, it will generally leak at that spot in the front, opposite corner rear, or exhaust side between cylinders 3 and 4 like my mine.
                          Sounds like you found your leak, but if you end up doing a head gasket, yes you want to replace the bolts. Along with a dozen other things... timing belt, water pump, valve cover gasket, all the head/intake/exhaust seals, and so on.
                          90 325i DD/Track
                          03 Durango 5.9
                          Originally posted by e30mpg
                          It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
                          • ClayW
                            • Apr 2011
                            • 377
                            Yeah, If it turns out to be the head gasket, I'll be doing a faster-than-I-had-hoped gasket refresh on my new spare M20 and I'll just swap the whole shebangabang.
