m20b25 with eta bottem end problems.
  • e-dirty619
    • 18
    so here it goes its been a big head ache.first off i am a bmw certified tech and have many resorces and still cant get this right. i have a 90 325i that the block was broken from and early accident and was jb welded. decided to get a 2.7 block from a friends old car. i swapped this 2.7 with all the i stuff. the vehilce will run rough slash lose power at rpms 2k-2.5k then again at 3k-5k then rips to redline. we have swapped out the fallowing with a known good vehicle: cps, iacv, cts, spark plug wires, coil, cap/rotor, afm, e36 injectors, main relay, fuel pump relay, new fuel pump, new o2 sensor, new spark plugs. fuel presure is good and never drops from normal. smoke tested intake and no huge leaks just normal little leaks. checked timing and timing is ok. when driving the vehicle at 1/2 throttle and below vehicle drives ok but not supper great. when o2 sensor is unplugged the vehicle has more power, but still has the same dead spots not really missfires. if anyone has any thoughts it would be greatly appreaciated. thanks everyone and sorry for the mess of a story ahahah:D
    BmMmduBbB teChHh
    • 37834
    Are you 100% sure the TPS, AFM, FPR, harness, DME, and spark plugs are correct for an i car?
    Grover Beach, California
    BimmerHeads.com
      As a BMW tech you should be aware of sensitivity of engine with EFI to intake leaks. I hope you fixed those small leaks as several small leaks add up to a major leak.
      • e-dirty619
        • 18
        yes the vehicle ran fine before the swap. It did hesitate a little but not as noticable as it is now.
        yea i know that intake leaks are bad and i will be fixing them but it just doesn't seem like it is problem concerning the small leaks. almost feels like the ignition timing is going crazy. if you guys think i should fix those leaks i could do that just to be 100% sure.
        BmMmduBbB teChHh
        • e30trooper
          • 11576
          give up and sell car. Easy
          • e-dirty619
            • 18
            Ahhaha to nice of a car to give up on. Might just throw in s50 and call it a day. I think I'm fallowing you on Instagram ahahaha
            BmMmduBbB teChHh
            • custom e30
              • Nov 2009
              • 347
              its your timing, it either needs to be advanced or 1 tooth or the opposite way, remember, your timing will be off because you have a I head and a E block,
              • frankenbeemer
                • Sep 2009
                • 2260
                I'm wondering about the timing too, but not because of the I head and the E block
                Don't buy an e30
                They're stupid
                1989 325is Raged on then sold.
                1988 325 SETA 2DR Beaten to death, then parted.
                1988 325 SETA 4DR Parted.
                1990 325i Cabrio Daily'd, then stored 2 yrs ago.
                • e-dirty619
                  • 18
                  I was kind of wondering the same as well. I've read more than I should have about this combo and no one has said anything about jumping a tooth in advance. I was thinking that it couldn't hurt anything to try it.
                  BmMmduBbB teChHh
                    Mating an I head to an E block does not require a change in cam timing.
                    • e-dirty619
                      • 18
                      after christmas i think i will recheck the timing. ive done many of these belts at the shop and at home. should i advance the cam timing one tooth and see how it goes?
                      BmMmduBbB teChHh
                        No!
                        • e-dirty619
                          • 18
                          No!
                          ok! When i get a chance im going to check the timing again and maybe swap out a known good engine harness
                          BmMmduBbB teChHh
                          • 2mAn
                            SeƱior Mod
                            • 21093
                            fix the leaks first....
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            Make R3V Great Again -2020
                              • 37834
                              What the hell are you talking about? NO.
                              BimmerHeads.com
