Victor Reinz headgasket starting to fail after only 20k??
  • vert_this
    • Feb 2012
    • 395
    #31
    Originally posted by 2man
    not sure if you are saying im fine right now, or that once its changed to drain the oil once its nice and hot??? can you clarify?
    What i do is make a quick oil change right afterwards, buy like a cheap filter for the first run to get the junk down and into the pan. Just run it good, heat it up then shut it off let cool down to where its just warm, open plug and let it drain until it no longer wants to drip. Then pull filter and wipe down mounting surface then replace with a decent filter refill and it should be fine.
    Oh and I can not stand Victor head gaskets its just not worth the possibilities, too much work to piss away on saving a few bucks.
    pelican sell OE HGs for like $100 that being said the VR kit is otherwise a decent deal for the other items.
    • ForcedFirebird
      • Feb 2007
      • 8300
      #32
      Just to give you a comparison of how bad this shit is, this was the first hint of what was coming. An oil change I did on 12/16/12
      oil change I just did
      Head is coming off this Thursday
      Anyone know what I could use to clean out the shit from the motor once the fresh headgasket is on there? I heard Lubrimoly has something, also heard something about ATF, but Ive never dealt with this before
      Put a gallon of ATF in your engine with a fresh filter. Take the t-belt off the oil pump drive. Use a drill with a socket on it to drive the oil pump, the ATF will get pumped through the engine and clean everything out. Drain it again and do the same with fresh oil.
      john@m20guru.com
      Links:
      • Mr. Burns
        • Aug 2011
        • 3516
        #33
        no love for Goetze?
        I've pushed 12psi on a Goetze on my 1st boosted e30, for 2 summers and the HG never failed.
        Originally posted by flyboyx
        i have watched my dog lick himself off a few times
        • 2mAn
          SeƱior Mod
          • 20902
          #34
          Can I do this after putting it all back together? Im ripping the car apart today and will be putting it back together this weekend. Timing belt will be off so it would be easy to flush the system with ATF and then install the new one
          Originally posted by Mr. Burns
          no love for Goetze?
          Goetze is one I am replacing the VR with and the one most people are recommending.... ;)
          Simon
          Current Cars:
          -1966 Lotus Elan
          -1986 German Car
          -2006 Volkswagen Jetta TDI
          Make R3V Great Again -2020
          • efficient
            • Feb 2012
            • 3312
            #35
            I bought a victor reinz then seen threads on how they failed so I bought a goatze with copper spray. Hope it lasts
            • Mfever
              • May 2007
              • 1058
              #36
              Why not just get an oe gasket from the dealer... put it in and forget about it. absolute best imo...
              • Cabriolet
                • 9620
                #37
                Most of the people here are cheap or are getting by on a budget. the one from the dealer is $80-110, the Erling whole set is less than that and the Goetze is like $20. However after seeing all of them side by side the BMW one is hands down better than all the others.
                Much wow
                I hate 4 doors
                • vert_this
                  • Feb 2012
                  • 395
                  #38
                  how are u doing this on an m20? u pulling the pan off? just wondering.
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    #39
                    I said exactly how to do it. Pour a gallon on ATF in your engine, same way you put oil in it and spin the pump. The oil pump is driven by the timing belt, no need to pull the pan. In fact most all engines have a way to prime it before running it.
                    I have done this with the pan off (engine on stand) by placing the sump pick up in a jug of fluid, but it makes a real mess when it drains back.
                    john@m20guru.com
                    Links:
                    • Mfever
                      • May 2007
                      • 1058
                      #40
                      yep... they just don't see that if you pay the premium price for the superior gasket, you won't have to take your head off 100 times either...
                      • vert_this
                        • Feb 2012
                        • 395
                        #41
                        yeah works fine with pump and pan off but I never have thought of using it on the front of the motor, I don't like doing anything that turns anything on the front of the motor with belt off. ATF does a good job of removing moisture. I wouldn't recommend doing this to a sludged up motor though. It will bust junk loose and have it loose in the motor=not good.
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          #42
                          yeah works fine with pump and pan off but I never have thought of using it on the front of the motor, I don't like doing anything that turns anything on the front of the motor.
                          How do you use the oil pump to pump if it's off? The oil pump drive has no contact with anything when the belt is off ;)
                          In fact, there's a trick to rotating your cam/head independently on an inline without worrying about vale to pistons contact.
                          john@m20guru.com
                          Links:
                          • vert_this
                            • Feb 2012
                            • 395
                            #43
                            yeah I meant pan not pump too.
                            Yeah but I'd rather not risk that move not so worried about the rotation as much as getting back to tdc.
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              #44
                              Thanks for the laugh tonight. I just spit a little beer through my nose.
                              john@m20guru.com
                              Links:
                              • 2mAn
                                SeƱior Mod
                                • 20902
                                #45
                                I dont think I want to, but I read that the Metric Blue headbolts can be reused??? I am wondering if that is a good idea, my other alternative is to use the new Victor Reinz headbolts. thoughts?
                                Simon
                                Current Cars:
                                -1966 Lotus Elan
                                -1986 German Car
