My <1,500mi M20 - *updated*
  • Gregs///M
    • Mar 2012
    • 2459
    Most likely a cracked head. Less common is a cracked block but mixing of the two fluids is usually cracked head.
    If the head was ever removed, it should have been checked for leaks, and re-leveled.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • JCarp90
      • Feb 2011
      • 1759
      I've been pretty busy so I have not removed the head but like I mentioned before, the head was completely gone through when I rebuilt it. It was tanked, decked, new valve seals, valve guides, valves etc.
      What's strange is that that little bit of gunk in the reservoir was all that was in my coolant. I'll take pictures but what drained out of the motor was green as could be. I really only had coolant in my oil - not so much the other way around.
      • JCarp90
        • Feb 2011
        • 1759
        Updated OP with new pics.
        • paperplane94
          • Jul 2011
          • 420
          So the problem was the headbolts?
          • JCarp90
            • Feb 2011
            • 1759
            That's what I'm suspecting. I'll get the head checked out to be sure. If it turns out the head work I paid a boatload of money for was shit, I might punch a baby deer.
            • dustyperez
              • Feb 2012
              • 390
              where ya gonna get a baby deer, can you get me one?? un punched for me plz
              • VAE30FTW
                • Jun 2011
                • 171
                H&R OE Sport Springs - Bilstein HD's - Kosei K1's ET27 - Toyo R888 - ZHP 5spd knob - BavAuto strut bar - DINAN Chip - E30 M3 Offset Bushings - Colgan bra - P-car daily
                • JCarp90
                  • Feb 2011
                  • 1759
                  I don't follow.
                  • e30trooper
                    • 11576
                    Metric blues are only good up to 12lbs at max. Its still better than stock head bolts. No offence if you spent 2k on your engine why cheap out on head bolts...
                    • JCarp90
                      • Feb 2011
                      • 1759
                      Tell me about it. FYI I wasn't boosted. I made that comment mocking the fact that I wasn't boosted and they still let go.
                      I put in metric blues with the intention of boosting when I bought a DD - ~9psi but haven't reached that point yet. With that being said, even before this happened, I had plans to pull the blues and do ARP studs before I ever put a snail on it.
                      • dnguyen1963
                        • Nov 2011
                        • 2648
                        Only 12lbs? I thought it can go up to 65lbs. Anyway, I would stick with OEM bolts.
                        • JCarp90
                          • Feb 2011
                          • 1759
                          I think he means 12 pounds of boost.
                          • monsterm20
                            • Jan 2013
                            • 33
                            I have a boosted m20 but head gasket blew. I have it torn apart and in the process of putting back together. I bought mb as head bolts. But now I'm thinking no. How much are ARP and Vic R's?
                            • dnguyen1963
                              • Nov 2011
                              • 2648
                              Makes sense...thanks.
                              • Andy348
                                • Sep 2009
                                • 688
                                Vic Rs I think are around $15 from Blunt.
                                ARPs are ~$240ish last time I checked, but I think they can be reused, which Vics cannot.
