victor reinz head bolts ok?
  • tinkerputzer
    • Jun 2008
    • 508
    Are victor reinz head bolts an acceptable alternative to bmw head bolts?
  • vert_this
    • Feb 2012
    • 395
    yeah just not the headgasket imo
      Some folks seem to have problems with the VR head gasket. I've used it on a number of engines and have yet to have a failure.
      • dougie30
        • Apr 2012
        • 1708
        Just bought the VR head bolts, haven't used them yet but when I do I will let you know hahah
        M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
        • e30mpg
          • Dec 2012
          • 187
          just used it on my head job. Do not know how well it will hold as my car is still in non functional mode right now. It felt fine when i torqued it down to 21 ft lb. and 2 right angle. I am also using VR head gasket too with some copper spray.
          • SkiFree
            • Jun 2011
            • 2766
            Originally posted by jlevie
            +1
            +2. Head bolts and gasket have worked just fine for me.
            ADAMS Autosport
            • vert_this
              • Feb 2012
              • 395
              my experience with victor HG's have been not that they blow but that like to ooze oil in the front side of the head. I have used them twice on two different m20's and the same result occured.
              • seatown88
                • 331
                I have used Victor Reinz head-gaskets and head bolts on several cars without any issues.
                • CptnVortex
                  • 46
                  Interesting, mine does the exact same... right at the front just under the distributor area. I thought maybe it was the valve cover seals but those seem fine. It really only leaks a very very small amount so I haven't given it much thought.
                  • vert_this
                    • Feb 2012
                    • 395
                    sounds like my Victor jobs. I'll never use them again I figure 0 for 2 and your done.
                    • phenryiv1
                      • Jul 2009
                      • 3246
                      So who is recommended?
                      Patrick Henry
                        Goetz or OE. The BMW OE gasket is reportedly better.
                        • phenryiv1
                          • Jul 2009
                          • 3246
                          Thank you!
                          Patrick Henry
                            • 34839
                            the bolts are fine. don't like the headgaskets. mine went completely after about 30k, and always seeped oil and coolant.
                            • sweet6e30
                              • Feb 2011
                              • 531
                              head bolts and gasket are just fine for me!!!
                              my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
