victor reinz head bolts ok?
  • 540er
    • 1
    i just put a fresh set of VR and about 200 miles so far with no leaks yet. I did use some copper spray, i think you guys should check your rocker shaft plugs, put some rtv on the crown and mine stopped leaking when i had thought it was from the VR gasket.
    • 603Racing
      • Dec 2010
      • 612
      Blew a gasket, replaced with VR gasket and bolts. Had head checked, cleaned, decked. Still leaks oil on exhaust side between cylinder 3 and 4. Not completely convinced it's the gasket though.
      90 325i DD/Track
      03 Durango 5.9
      Originally posted by e30mpg
      It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
      • mrgraphics
        • 221
        Head bolts are good, but when I held a Goetze and a VR headgasket side by side, the quality difference was night and day. Needless to say, the Goetze went on the car.
        • Bolestuff
          • May 2012
          • 51
          I just checked a new set of VR head bolts and half are slightly to very bent. This could have been a very bad day! Check it out
          • Cephas
            • Apr 2012
            • 878
            Yikes.
            • SkiFree
              • Jun 2011
              • 2766
              At the time that this post was made (2012), VR Headbolts were fine. They were straight as could be.
              However, about two years ago they started coming in bent like what you describe. Since then I've been using OEM headbolts which are not but a couple dollars more.
              ADAMS Autosport
              • JGood
                • Jan 2004
                • 7959
                Yep, just went through this with a set of VR m20 head bolts as well. Half were bent, just like in the video above. I'm baffled as to how they are still selling them. The return rate must be through the roof, there's no way they are making money on them.
                About 2 years ago, I used VR bolts to build an m60b44. They were all straight, but one of them looked like it went through the threading machine sideways, then went through it again upside down, then drug behind the UPS truck the whole way to my house. It was barely recognizable as a bolt by the time I opened the box. The rest seemed fine.
                e30 restoration and V8 swap
                24 Hours of Lemons e30 build
                • TobyB
                  • 5296
                  Out sourcin', out sourcin', oh hey!
                  Since they're TTY, they'll just straighten themselves out, righty- ho?
                  This is not going to improve as time goes by, I fear...
                  t
                  • Cabriolet
                    • 9620
                    this is very true.
                    for the $10 difference just get the bmw headbolts
                    i've had no failures with goetze, BMW and erling (when sprayed) head gaskets
                    Much wow
                    I hate 4 doors
                    • Kershaw
                      • 11822
                      I've had 3 VR head gasket failures. All done within a year of each other. I learned my lesson. Never using VR again. Compression is fine. Runs great. Oil seeps out near the cylinder 1 exhaust side. That whole area is wet. It sucks. I've been dealing with it for 3 years now but one of these days I just have to suck it up and replace it.
                      AWD > RWD
