FML dry head?!
  • Slicktop_serg
    • Nov 2011
    • 198
    FML dry head?!
    So i finish putting my cooling system back together and started the car up and i opened the oil cap and saw that the head was dry.... sooo im stumped at the moment any ideas?
    91' Alpine II 318is Slick top - Totaled
    89' Lachssilber 325is - :p
  • Exodus_2pt0
    • 5943
    Oil pressure warning light going out?
    No E30 Club
      • 37828
      If the head was dry and not getting oil trust me you will know and you will know quickly. Rev it up with the cap off and take another look.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • Slicktop_serg
        • Nov 2011
        • 198
        Oil pressure light on cluster :/
        My oil pressure light is on. And i took off valve cover and there was barely any oil :/
        • Exodus_2pt0
          • 5943
          If the oil pressure light is on, check your oil pump. Don't run it any more until you do.
          What work did you perform leading up to this?
          No E30 Club
          • Gregs///M
            • Mar 2012
            • 2459
            Check your oil level first.
            Owner - Bavarian Restoration
            BMW and European Electronics Repair and Restoration
            www.BavRest.com
            My Feedback Thread
            Our Facebook!
            Follow our Instagram!
            • Exodus_2pt0
              • 5943
              Yea, that too. If you did a head gasket I hope you changed the oil, otherwise you could have a layer of water on the bottom of you pan. Which would explain the lack of pressure.
              No E30 Club
              • sweet6e30
                • Feb 2011
                • 531
                did you take the head apart> ?? improper installation/orientation of the rocker arm shafts would restrict and/or prevent oil flowing to the head.
                what other work did you do ?
                my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
                • Slicktop_serg
                  • Nov 2011
                  • 198
                  Fml
                  No i had to replace the oil pan. and replaced oil pump with a used one. So im guessing the used pump went to the SHITTER.... its a bummer :-?. Now i have to take oil pan off again and get a brandnew pump so it doesnt happen again... pelican parts is my E30's fav -_____-
                  • TimKninja
                    • 2131
                    I had a problem where the dude who rebuilt my head never out the rocker shaft retaining clip back In.
                    The rocker shafts spun and cut off oil flow to the head. Went to the JY picked up a new clip and was ready to go.
                    Did you prime the used pump?
                    1985 325e M50TU(Sold)
                    1991 318is Slicktop (Sold)
                    1990 325is Brilliantrot S50/5 Lug Swapped.
                    1992 525i Manual shitbox Winter Beater
                    • Exodus_2pt0
                      • 5943
                      This, pack a new oil pump with petroleum jelly. It acts as a primer then breaks down.
                      No E30 Club
                        It isn't a big deal to prime the oiling system. You remove the cover from the boss on the left side of the engine where an old-type distributor would mount. Then pick out the oil pump drive gear. A 6mm socket will fit the oil pump drive shaft and a long extension and a drill can then be used to drive the oil pump. Using a 3/8" drill I can typically get about 30psi on an engine I've rebuilt.
                        • FLG
                          • Sep 2011
                          • 3165
                          Jim,
                          What direction do you need to drive the pump? Just out of curiosity.
                          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                            Clockwise.
                            • Slicktop_serg
                              • Nov 2011
                              • 198
                              Found something out
                              SO i found out that im missing the lil drive shaft that goes from the crankshaft to the oil pump. Does anyone know the part number for that? cause i cant find it.
