Performance valve springs
  • DEW
    • 26
    Whose set is best? What are the options? I know of VAC, Metric Mechanic, and Schrick. Are there others? Also wondering if there's anywhere the Schrick springs can be bought besides Turner.
  • whodwho
    • Jun 2008
    • 1547
    What cam will you be running? A fresh set of stock springs will work for most street cams or a set of MM beehive work well with mild cams.
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • DEW
      • 26
      Probably something in the 288 range but if I am replacing springs I figure I may as well upgrade too...
      • JCarp90
        • Feb 2011
        • 1759
        I believe I've heard before that someone uses Honda B series dual valve springs. I'll try and see where I got that from.
        • digger
          • Nov 2005
          • 6119
          i would use VAC or Schrick for the 288
          • DEW
            • 26
            Any idea on where to purchase Schrick springs stateside other than Turner?
            • burlmays9
              • 227
              Yeah please try and find out if that's true 'cause that valvetrain is cheeeaaap
              • digger
                • Nov 2005
                • 6119
                unlikely to find them significantly cheaper than turner unless lucky enough to find a private sale
                • TrackjunkiE30
                  • Sep 2009
                  • 151
                  I went with VAC and it took forever to get them.
                  John
                  2013 NASA-SE TTE Champion
                  Tracks driven: AMP, Barber, CMP, CMS (Lowe's), Daytona, NCCAR, Road Atlanta, Rockingham, RRR, Sebring, Texas World Speedway, VIR (Full, Grand, South, North, & Patriot), Watkins Glen.
                  • digger
                    • Nov 2005
                    • 6119
                    funny i once bought from VAC on a Friday and they shipped to me in OZ by the Monday, wasnt cheap but.........
                    • DEW
                      • 26
                      Bumping this one more time in case there are any other options I have over looked.
                      • Bimmer_man
                        • Jan 2013
                        • 1477
                        VAC is the best choice in my opinion. They have a lot of experience with these cars and are amazing.
                        Float like a cadillac sting like a Bimmer!:)
                        • SkiFree
                          • Jun 2011
                          • 2766
                          I would be very picky on dual valve springs. Ask for specs on the VAC springs to compare them to MM and/or Schrick. I'd be personally inclined to go with either MM or Schrick over VAC (but obviously specs are needed).
                          A spring manufacture typically will want an order of at least 5k-10k springs before it becomes somewhat cost effective to the supplier. The likely-hood that VAC would have made that kind of investment on the lowly M20 is doubtful in the extreme, which would mean their springs are sourced from another vehicle.
                          ADAMS Autosport
                          • digger
                            • Nov 2005
                            • 6119
                            ive used the VAC ones for the past 4 years or so after coming from MM ones. they have higher open and closed forces but they work really well and are made by Eibach
