M20 Camshaft Removal (Update)
  • -bimmerboy-
    • Jan 2013
    • 85
    Decided I didnt want to spend the $1500 to get my cam put in since I'm only 17 and dont have that kind of money haha so after 3 days this is where I'm at. Everything has been relatively easy with no problems what so ever. Just slid the cam out today so the new 272 goes in tomorrow!
  • kamotors
    • Nov 2007
    • 7102
    link doesnt work. but good job on the DIY
    7speedshop.com
    • enigmaticdream
      • Jan 2010
      • 572
      Installing the new cam will be a bit more difficult than removal. You'll be applying more and more tension on the cam as you install each rocker arm. Just take your time and check that each rocker is in the right location as you turn the cam over.
      Do a valve adjustment after your done. It is a lot more comfortable with the head outside of the car. I made marks with a sharpy on the head after a valve was adjusted. I did two passes.
      1986 911 Supercharged Frakenstrat/Stripped
      1987 325is Delphin/Black (Olga)
      1988 M3 Zinno/Natur (Elsa)
      Manual or STFU
      E30 Chapter of BMW Car Club of America
      E30 Oktoberfest 2017
      • whodwho
        • Jun 2008
        • 1547
        Read up on breaking in cams, don't remember if this was a new one but still wouldn't hurt to break it in like one. ;)
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
        • ForcedFirebird
          • Feb 2007
          • 8300
          If the procedure is done properly, it's not difficult at all. I can't stand it when heads come in the shop that someone previously hammered on the rocker shafts. Even the Bently says to tap them out, when all you really have to do is remove the eccentrics.
          Originally posted by whodwho
          Read up on breaking in cams, don't remember if this was a new one but still wouldn't hurt to break it in like one. ;-)
          It's also a good idea NOT to use old rockers on a new cam, and make sure you are using oil with enough ZDDP.
          john@m20guru.com
          Links:
          • enigmaticdream
            • Jan 2010
            • 572
            I didn't think to remove the eccentrics. I herp and derp a lot though. Would have made trying to keep everything aligned and lubed a lot easier...
            Another thing OP make sure you get assembly lube.
            Manual or STFU
            • -bimmerboy-
              • Jan 2013
              • 85
              M20 Camshaft Update (with pics)
              Okay so heres what i've got so far:
              Head is completely off as well as rockers and cam removed. New cam goes in today. Anybody have any tips?
              • bmwguy325is
                • May 2011
                • 1263
                interesting header.
                sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                • Scallywagon
                  • 1200
                  Get ZDP addittive and break her in
                  ( f ; _ ; )f
                  • ak-
                    • 12422
                    Shouldn't your o2 or wideband be installed at the collector down below?
                    1991 325iS turbo
                      Yes it should be located at a point where it can see the exhaust from all six tubes.
                      • jeffnhiscars
                        • Jun 2011
                        • 6011
                        ... and make sure you are using oil with enough ZDDP.
                        John, can you suggest a good source for ZDDP additive ?
                        TIA
                        Alice the Time Capsule
                        • -bimmerboy-
                          • Jan 2013
                          • 85
                          Yes, that would be much appreciated if you could let me know that.
                          • -bimmerboy-
                            • Jan 2013
                            • 85
                            I was thinking the same thing when my exhaust shop put them on....
