what is faster?
  • dougie30
    • Apr 2012
    • 1708
    what is faster?
    A stock m20b25, or a 2.7i? I read a few old threads about how the 2.7 makes more torq but the 2.5 makes more HP...
    So I have a m20 b25 motor but the block needs to be resurfaced, and I can pick up a eta block for cheap so I was wondering what's faster because both are in reach for me.
    M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
  • 603Racing
    • Dec 2010
    • 612
    Depending on the machining costs you're looking at, the eta route may be cheaper. Maybe.
    If you're looking for "faster" per dollar, you may want to look into other motor swaps.
    90 325i DD/Track
    03 Durango 5.9
    Originally posted by e30mpg
    It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
    • Cabriolet
      • 9620
      the drive makes the car faster
      if you do the full eta bottom and I top then you really will want to boost the engine.
      but at that price you can swap in an s52 and get NA power
      Much wow
      I hate 4 doors
      • LJ851
        • 7919
        The blocks are the same, the crank, rods, and pistons are different.
        A stock i will eat a stock e's lunch, it has 40 more horsepower.
        Lorin
        The M30 is God's engine.
        • dougie30
          • Apr 2012
          • 1708
          yea i understand all of that. but what i was wondering was a stock i engine vs a i head on a e bottom end, which would be faster.
          no boost or s50
          • vert_this
            • Feb 2012
            • 395
            no boost or s50
            stock I motor
            • dougie30
              • Apr 2012
              • 1708
              Originally posted by vert_this
              stock I motor
              Thanks
                • 37833
                My buddy Myster-e built a 2.7i using a stock Eta bottom end with one of our 885 heads. It of course had all i electronics and top end parts along with a 3.73 LSD. That setup would have handed a stock M20B25 its ass.
                A lot of people on the internet talk down this setup but have never actually done it.
                Grover Beach, California
                BimmerHeads.com
                • e30m20TurbO7
                  • 1203
                  ive done it and loved it before i spun some rod bearings , but im still putting it back together , when i could go 24v or around 300 bucks more
                  • dougie30
                    • Apr 2012
                    • 1708
                    Don't the mr-e heads come with a cam though?
                    And wouldn't the 2.7i be really low compression? With out a turbo obviously
                    • e30m20TurbO7
                      • 1203
                      yea the CR is a lot lower than stock , but im a boost freak so its all gravy
                      • Cabriolet
                        • 9620
                        Stock I is 8.8:1, 2.7i is 8.5:1 it's lower but not a "lot" lower
                        Much wow
                        I hate 4 doors
                        • e30trooper
                          • 11576
                          Id say my car feels faster than a stock b25.
                          ETA 2.7L block
                          Decked 885 head
                          Adjusted AFM
                          alpina b3 rep chip
                          3.73lsd
                          full motronic 1.3 conversion.
                          3rd gear chirp on bottle caps with newish 195/60/14 tires
                          And yes big heavy 86 dualmass flywheel and bad rings for cyl 6.
                          • 2mAn
                            SeƱior Mod
                            • 20997
                            Torque makes a big difference. My car is a stock eta bottom end with an 885 head. 19# injectors, 3.5bar FPR & Mark D Chip and 3.73 LSD. Im confident I would beat a 325i with similar mods. Of course, I also weigh a lot less than most E30s. I even kept up with my buddies S50 car on a pull to a 100mph
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            Make R3V Great Again -2020
                            • M44schnell
                              • Apr 2012
                              • 123
                              Super ETA bottom end+885 head+new double valve springs, rockers and cam (284/272)=the east way to go for more than stock b25 and not lowered compression. Just my .
                              But as stated above a 24v swap is cheaper and easier for more gains but having a nice M20 is cool (and sounds tiiiiiiiiiiiiiiiiiiiiiiits )
                              Also with a 3.73LSD it wakes a huuuuuuuge difference over the 2.93 i used to have. A 327i with out the 3.72 that isnt boosted is a injustice
