2.7i - Shrick 288 Cam and springs
  • kid325e
    • Sep 2007
    • 6422
    I'm curious how a 2.7i in stock form (Eta block and pistons, 885 head, with Motronic 1.3) would take to a Shrick 288 Camshaft and Valvesprings. This engine is going into my drift/track car, comfort, and driveability in the city isn't really a concern of mine. Will the stock FI and ECU be fine untill I can afford Megasquirt or WAR chip?
    I'm also considering the 284 but I want the money to be well spent. ;)
    Sent from my GT-P5113 using Tapatalk HD
    clutchCTRL!
    Move with a purpose.
    - 1991 325iX 4dr/5spd
    - 2000 323i AT
    2016 Mazda CX3 Sport AWD
  • digger
    • Nov 2005
    • 6198
    do it and report back......
      • 37833
      I'd go with something smaller than a 288 for sure.
      Grover Beach, California
      BimmerHeads.com
        • 34844
        your compression is way too low for that cam. even a 284/272 is probably too much. Honestly, I think the best cam for that setup would be a stock M20B25 one.
        with a 288 my guess is your power band will last for about 500rpm and not be very impressive in magnitude either. you want something like 11:1 for the 288 and you've got about 8:1.
          • 37833
          We've done an engine like the OP's with one of our heads and 274 cam.
          Power was awesome and it was still very torquey.
          BimmerHeads.com
          • LJ851
            • 7919
            Yes.
            The rule of thumb is more cam needs more compression.
            Your 2.7i setup has less compression so big cam is no bueno.
            Lorin
            The M30 is God's engine.
            • Andy348
              • Sep 2009
              • 688
              Hypothetically, if he ran SETA pistons (which I believe raise compression, or rather lower it less), would a 272/288 be more beneficial?
                • 34844
                no. 8.5:1 isn't much of an improvement.
                • kid325e
                  • Sep 2007
                  • 6422
                  Thanks for the input guys!
                  Looks like i'm going to choose between a Brand new STOCK cam, or a 272 or 274 cam from Myster e Performance.
                  Still open to input and experiences!
                  clutchCTRL!
                  - 2000 323i AT
                  • darvo
                    • Dec 2010
                    • 407
                    Go with the 274 MR.e .... Awesome guys, great product! Money well spent
                    • digger
                      • Nov 2005
                      • 6198
                      .........its good to see that people realize that his static CR will be lower than what the DCR should be, and would run terrible........ something smaller duration but similar LSA is much better
                      i would at most use a 272 if nothing could be done to raise the comp but if the Mr E tell you the specs of their cam then you might be able to choose the best one. A single duration figure is meaningless especially an advertised duration....
                      • homegrone30
                        • Jun 2007
                        • 1449
                        I will be hitting you up after I get my tax return.
                        Sent from my SPH-L710 using Tapatalk 2
                        • homegrone30
                          • Jun 2007
                          • 1449
                          Lol clicked the wrong link
