Weak Cranking Power
  • K1CKBAC
    • 306
    Weak Cranking Power
    Hey guys,
    Been hunting down why my car won't even start and just noticed my car is really weak cranking power. When I start the car, it would crank for about 1/2 a rotation and then stops with clicking sounds. I double checked the battery for power and tested good, also tried another good battery but it still won't start. What else can cause a car to have low cranking power? Alternator grounding cable a probable cause?
    My expectation is an immediate 5 speed swap. Autos suck more than a 50 year old whore.
  • TurboJake
    • 3780
    Chassis grounding cables. Engine, and battery.
    Smaller likelihood it's the positive cable.
    The alternator does not help with cranking ;)
    Leave Me Transaction Feedback
    • K1CKBAC
      • 306
      I'll double check the ground cable but it is new.
      • dougie30
        • Apr 2012
        • 1708
        Starter?
        M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
        • bmw325csi
          • May 2007
          • 4045
          Originally posted by dougie30
          Starter?
          Isn't this the oblivious answer?
          harry/harout
          • dnguyen1963
            • Nov 2011
            • 2651
            Oblivious or Obvious?
            • dougie30
              • Apr 2012
              • 1708
              Haha thats what I'm saying
              • amcink
                • 788
                Battery is bad
                • K1CKBAC
                  • 306
                  Update: Thanks for the input guys. Battery was fine, starter was fine. It was my ground cable from engine to chassis. Although it is only a few months old, it developed a lot of resistance for some reason.
                  • VAE30FTW
                    • Jun 2011
                    • 171
                    Awesome! This is a good way to test as well
                    Did you also clean up (with a scotch pad) the mating surfaces of the ground cable? If there is a layer of rust it will have resistance. I usually coat the surfaces with a bit of dialectric grease.
                    H&R OE Sport Springs - Bilstein HD's - Kosei K1's ET27 - Toyo R888 - ZHP 5spd knob - BavAuto strut bar - DINAN Chip - E30 M3 Offset Bushings - Colgan bra - P-car daily
                    • K1CKBAC
                      • 306
                      Wow that is a great way to test. I did not put any diaelectric grease because I'll be pulling the motor for a rebuild in less than 2 months.
                      • VAE30FTW
                        • Jun 2011
                        • 171
                        Cool, just don't cake it up and make sure the pressure from the ground strap squeezes most of it out.
                        • Gregs///M
                          • Mar 2012
                          • 2459
                          Be sure to clean the surface of both the oil pan bolt and frame rail stud. I use a wire brush attachment on a air tool. You want nice clean shiny metal. Then secure the ground cable well.
                          Also do this to the mounting points when installing a new starter or alternator.
                          Owner - Bavarian Restoration
                          BMW and European Electronics Repair and Restoration
                          www.BavRest.com
                          My Feedback Thread
                          Our Facebook!
                          Follow our Instagram!
