replaced everything but still no spark?
  • J.Rizo
    • Aug 2012
    • 949
    I have a '87 325i vert.
    after sitting for a while my car isn't starting.
    I replaced the spark plugs, the cap and rotor, and I had the coil pack tested and it was good. my stepdad tested to see if it was getting spark and no luck. and I recharged my battery so that isn't a factor either, and I definitely have gas.
    my dash lights up and my motor turns over, but it just can't get there. starter fluid isn't helping either.
    my question is what else could it be? what am I forgetting? All helps appreciated. thanks guys!
    @joshua.j.rizo
    Originally posted by SpasticDwarf
    Just remember next time you hear "late night when you need my love" I'm gonna be sitting somewhere way more bitchin' than you, driving or not.
    BUY MY BUGATTI WHEELS:
    http://www.r3vlimited.com/board/showthread.php?t=377693
    WRITEUP TO MY RHD SWAP:
    http://www.r3vlimited.com/board/showthread.php?t=371904
  • LJ851
    • 7919
    crank sensor
    Lorin
    The M30 is God's engine.
    • IRON-E
      • 16548
      Yeah, was gonna say CPS
      @IRON-E30 aka Edwin:D
      • E30_fiend
        • Apr 2006
        • 7348
        I will be the third person to suggest the crank sensor
          Yep, CPS, main relay, or fusible link would be the obvious suspects.
          • jeffnhiscars
            • Jun 2011
            • 6011
            Main relay is $11 from the dealer and 60 seconds to replace (if its your first time). Id start there. Better yet,I swapped one in from another car to confirm that was the problem
            Alice the Time Capsule
            • J.Rizo
              • Aug 2012
              • 949
              thanks guys! I'm glad there was an obvious go to everyone thought of. I'll let you guys know what happens.
              @joshua.j.rizo
              • Quinthirty
                • Mar 2012
                • 318
                Check fuel delivery. When you say sitting for awhile, how long did it sit? Your fuel can also be stale if its been a long while.
                • e30s52
                  • Oct 2007
                  • 5235
                  You might want to see if the cam is turning also lol.
                  www.gutenparts.com
                  • J.Rizo
                    • Aug 2012
                    • 949
                    quinthirty about two months.
                    FOLLOW UP QUESTION!
                    on pelican parts, there's two options, both of which are applicable to my model.
                    ones "cps motronic engine (front of engine)" and "cps/rpm sensor".
                    this might be an obvious answer but I don't know which one I need. and help?
                    @joshua.j.rizo
                    • Jahman093
                      • Sep 2012
                      • 183
                      motronic (front)
                      also if cps still doesnt give you spark dont be afraid to try another ecu
