Broke one intake side rocker arm at a drift event last week. Was going to adjust valves and discovered I actually broke on off, it failed near the eccentric. Anyways, I have extra rockers (used) that I was going to use to replace it for now, later on I want to pull the head and replace valves/springs/rockers w/ heavy duty. If I can't get the rocker arm out with the head still on I'm planning on pulling the head and replacing the head bolts and gasket. Anything else you guys would suggest, obviously I'm going to inspect the timing belt/tensioner, water pump, thermostat etc. But the motor was just recently dropped in (donor w/ 140k), and the TB, water pump, all that was replaced.
Ah, this is also my first post on here, having trouble finding much information on my local forum, look forward to learning and contributing here!
Travis
Travis
