154 seta ECU with 2.7i?
  • SmokeE30
    • 1730
    I have a 88 seta, this weekend I'm going to be doing a tb, Headgasket waterpump ect. While I have it apart I am thinking I might as well make it a 2.7i but I don't have any I car ECU's laying around, only sets 154's. Has anybody run the 154 with this setup? I know it should run but how well I don't know, I have stock and Dinan chipped 154's on hand but don't want to risk leaning it out untill I can grab a 153 or 173 ect.
    Shawn @ Bimmerbuddies
    Bimmerbuddies LLC
    717-388-1256
    2971a Roundtop Rd, Middletown PA 17057
    bimmerbuddiesllc@gmail.com
  • TheTacoMan
    • Nov 2011
    • 2308
    I never ran my seta with the 154, had the 173 in when I bought it. But your car will have a low rev limiter and might run a little funky, make sure you upgrade the afm too!
    • SmokeE30
      • 1730
      The chipped ECU I have will let it rev to 6k (at least that's as high as I've pushed the single valve springs) so I'm not supper concerned about the rev limiter at the moment. I have everything else though, afm, head, intake, tb.
      Bimmerbuddies LLC
      717-388-1256
      • TheTacoMan
        • Nov 2011
        • 2308
        It will be run better with the 173, its tuned better for a 2.7i.
        • SmokeE30
          • 1730
          Did you change injectors? I've never seen a reliable source for what injectors the SETA came with, I just know they are different than I cars and E cars.
          Bimmerbuddies LLC
          717-388-1256
          • reelizmpro
            • 9553
            No one made a chip for the Super ETA 154 DME so I'm confused. This would be the first I've heard of it and I have the Dinan literature on my desk. Anyway, I wouldn't run the car on that DME. You can but it's not ideal. Don't run the super ETA injectors or FPR.
            88 M3 - LACHSSILBER
            89 M3 - ALPINEWEISS II
            • TheTacoMan
              • Nov 2011
              • 2308
              I have the "i" fpr and 19lb injectors.
              • Swanny
                • Mar 2012
                • 2834
                How is that working out? Whats you mpg like?
                Swanny!
                SUCKERS.
                • SmokeE30
                  • 1730
                  You know I have seen very few chips for the SETA, It could be a eBay knock off Dinan chip or something, I know Marc d made some, I'm going to check for myself though because there is a good possibility that the PO that thought the car was a 325i may have put an I car ECU and chip in it.
                  Edit
                  Well what do ya know i poped open the ECU cover to find a 153 just chilling there not bolted to its brackets. So that's why I can wrap my 6k tach...
                  Bimmerbuddies LLC
                  717-388-1256
                  • SmokeE30
                    • 1730
                    Why is this? I have some m50 injectors with one broken pintel cap laying around but no I car fpr that I'm aware of, I'll have to look. What pressure does the seta and I cars run at and what are the injectors on my seta?
                    Bimmerbuddies LLC
                    717-388-1256
                    • TheTacoMan
                      • Nov 2011
                      • 2308
                      I get about 24mpg
                      Look up strictly eta.com, its has some seta info on their fpr
                      • SmokeE30
                        • 1730
                        ok from what i have been able to find, the SETA FPR is 2.5 Bar vs the 325i 3.0 bar FPR
                        im still digging for injector info as i keep getting conflicting info everywhere i look, but im thinking my SETA injectors may be sufficent at 3.0 bar vs the stock 2.5 bar.
                        edit found this info which seems pretty ligit but 12.75lbs seems pretty weak, i thought it would be higher like standard e cars
                        Stock SETA Injectors: 0 280 150 716 Bosch / OE: 13641466261 / Flow Rate: 12.75 / Impedance: High
                        Stock 2.5i Injectors: 0 280 150 715 Bosch / OE: 13641734776 / Flow Rate: 14.5 / Impedance: High
                        M50 Injectors: 0 280 150 415 Bosch / OE: 13641730060 / Flow Rate: 17.5 / Impedance: High
                        EDIT#2
                        so if the 12.75lb flow rating @2.5 bar is correct, by going to a 3 bar FPR it would flow 14lb, so still a little off the 14.5lb of the stock i injectors but probably ok to run.
                        however if i used the m50 injectors that are 17.5lb @ 3.0 bar with my SETA FPR they would flow 16lb @2.5 bar which should be perfectly fine as well but i think either one is within the range of the ECU's ability to compensate for.
                        so i guess it will just depend on what i can find tomorrow morning, a m50 injector pintel cap, or a 3.0 bar fpr.
                        and i thought i had all this shit i needed laying around... its always something
                        Bimmerbuddies LLC
                        717-388-1256
                          • 37833
                          The standard Eta injectors are low impedance so their rating is different.
                          Do yourself a favor and install a set of M50 injectors and a 3 bar FPR. Trust me.
                          Grover Beach, California
                          BimmerHeads.com
                          • SmokeE30
                            • 1730
                            From what I have read the seta and I car injectors are the same impedance, unlike early e car injectors. I realize the m50 injectors are and improvement just based on the pintel design alone but the fact that they work on my system leads me to believe they are the same impedance as well.
                            Im going to try to get a pintel cap for my m50 injectors to run them, and attempt to find a 3.0 bar fpr as well. And if I can't find the fpr I need I'll just crush mine to make it a 3.0 bar.
                            This website is for sale! snstuning.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, snstuning.com has it all. We hope you find what you are searching for!
                            Of course this happening today depends on if my parts from blunt show up today
                            Bimmerbuddies LLC
                            717-388-1256
                              • 34844
                              the seta ECU is the same thing as a 153 with a different chip.
                              I'd use a 173, or later, and a custom chip. the 154/153 is a complicated 2-board setup and isn't very reliable.
