Head gasket job done incorrectly
  • Cronopoulos
    • Jul 2011
    • 2187
    The HG's are the same. The block is essentially identical between the 2.5/2.7
    Is it possible your exhaust manifold gaskets are new and the smoke you see is just the gaskets breaking in?? Just a thought. Also you made sure the heads (2) alignment dowels were used and the head was sitting flush with the hg/block?
    Project log -- DIRTY 30
    2.7i * Megasquirt tuned * E85 powered
    • AndrewBird
      The Mad Scientist
      • 11897
      It's possible that your block may be cracked, however, unlikely. Did the car overheat before you pulled the head?
      • Habla
        • May 2004
        • 1470
        This would be a dumb answer, but it could just be a coolant cook-off from the exhaust manifolds. I got coolant everywhere when I did my HG. Took it for a drive, and there was smoke billowing everywhere.
        -Peter
        318is slicktop | F15 35dM | F250 SD
        • dsphil
          • 495
          ^. Yes. False alarm. I sprayed brake clean under the exhaust and run it 10min and no more smoke. Hopefully things will held up for the extra 10deg I put into the head bolts.
          327is
          325es
          325es
          318is
          Fiesta ST
          E46 M3
