Noob here need help with ticking
    So i know a lot of people say a ticking engine is a happy engine or somewhere along those lines and i get that but as of recenetly after a spiritied drive through the Berkley hills there has been a loud knock that shows up around 3000 rpm and up. Went to check the valve clearance and noticed that some rocker arms when the cam lobe is TDC that there is a gap between the two and with your hand can be made to click. I guess my question is could the sound be the rocker arm slapping against the cam lobe durning rotation? i dont know much about cars so this is baffling me haha thanks guys:bow:
    Does it sound like its coming from the bottom or top end?
      well if your thinking thats what it can be then do another valve adjustment and see if it goes away..but im not 2 sure since you say its a "knock"
      93 325i 120k
      mods: straight pipe,eibach sport springs,style 54s,kamotors carbonfiber cai,
      future mods: chip, m3 cams, headers, turbo
        Definitely do a valve adjustment first (.010 gap between the valve stem and rocker for intake/exhaust). A slight tick is okay, but you shouldn't hear it at high rpm. A knock is a totally different problem and usually requires a good bit of money to make it go away (rebuild).
        1989 325i Lachssilber Sedan
        5-Speed Swapped
        M30B35 Swapped
        MegaSquirt MS3X
        1987 325i Lachssilber Sedan
        260k OEM Automatic Daily Baby
          sorry im late on the reply but after getting the car diagnosed it came to be rod knock. recently have started the rebuild just am waiting on some parts now! any suggestions while the engines out i.e. cheap mods performance,cosmetic anyting?
            ^search
            Derek-
