Noisy engine
  • BROKINBIMMER
    • Nov 2012
    • 195
    Noisy engine
    Fresh valve adjustment, fresh oil, new exhaust w new high flow cat and new muffler. Unable to determine if a leak is present, but motor is very loud from outside car and from inside while driving....Should I pull the exhaust manifolds and replace the gaskets/studs/nuts?
    Not until you find out if that is the source of the noise.
    • dnguyen1963
      • Nov 2011
      • 2651
      It depends on the type of noise you are hearing. High flow Cat and muffler can increase the exhaust noise ten folds easily.
      • EatsHondas
        • Sep 2012
        • 404
        Suck in Seafoam through the vacuum hose that runs from the intake to the regulator. You'll smooth your idle and initial throttle response, and white smoke will seep out of any exhaust leaks you may have. I didn't know I was leaking out of the downpipe(s)/manifold connection until I did this.
        Stock cats are very restrictive (9 bhp difference according to BMW http://en.wikipedia.org/wiki/BMW_M20) and quiet the motor considerably. High flow cats combined with a new muffler SHOULD make your engine considerably louder, and it's usually thought of as a plus.
        1989 325i Lachssilber Sedan
        5-Speed Swapped
        M30B35 Swapped
        MegaSquirt MS3X
        1987 325i Lachssilber Sedan
        260k OEM Automatic Daily Baby
        • nickmcc92
          • Dec 2012
          • 442
          X2 on seafoam.
          My valves are adjusted to .008" not spec .010" because my car's 25 years old.
          • BROKINBIMMER
            • Nov 2012
            • 195
            Good to know, did replacing those gaskets quiet it down a bit?
            Also, spent yesterday replacing exhaust manifold gaskets and new manifold hardware.
            • EatsHondas
              • Sep 2012
              • 404
              Unfortunately I don't remember hearing any difference. The car didn't run any differently/better either. All I got was the satisfaction of there being one less thing wrong with my car. :|
              5-Speed Swapped
              M30B35 Swapped
              MegaSquirt MS3X
